AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Can you identify this subwoofer?
post #1 of 12
I found a pair of these in a friends garage, and he gave them to me. He knows nothing about them.
They are 9 inch woofers in a 13 inch diameter cabinet about 3 feet long. The base is black veneer. It looks like the front had a trim ring or something to hold the outer cloth.
There are no logos, model numbers, or brand names anywhere on them. The woofers have the number 45109-9 printed on the cone. The magnet has a sticker with the number 10530, 16 ohm. It also has another number 67-93370043 G4 on it.
They look too professional to be home made.
Any info would be great, as I would like to re-cone them if possible.
Keen
post #2 of 12
Keen
post #3 of 12
I don't think they are for a car. No amp, and they are 16ohm.
Keen
post #4 of 12
Not 100% but looks like a 90's HSU Research cylinder sub HR or TN perhaps.
I think they were 16ohms cause they were normally pairs and ran as 8ohm off the external amp.
post #5 of 12
Ya, looks like an older HSU TN1220
EDIT: Nevermind, NOT A TN1220!!!
Edited by edoggrc51 - 8/29/12 at 6:15pm
post #6 of 12
The TN 1220 used a 12" driver and it had the driver on one end and the ports on the other end of the column. So I don't think this sub is a TN 1220.
Crag
post #7 of 12
Crag
You're absolutely right. Just looked at some of my old pics to confirm. I'll edit my post. Thanks!
post #8 of 12
Early Hsu subwoofer - probably the HR-10.
post #9 of 12
Thank you. That put me on the right track. I finally found a good photo of them on the net. They are Hsu HRSW10's.
Now to the point, does anyone offer a re-cone kit for them?
Keen
post #10 of 12
Keen
I have a couple of those drivers and I believe that Hsu was using Eminence for drivers at that point. Any good repair shop (Orange County Speakers or others) should be able to fix them relatively cheaply.
Jim
post #11 of 12
Those looks like Shiva's to me except that they were 12" not 10" wow those brings back memories.
post #12 of 12
The Shiva's were made be Eminence as well, so the "family" resemblance is understandable. Any competent reconing service could easily fix them for you.
Jim
