Need help to decide if I should go with in-wall, on-wall or a LCR box system.
My budget is $1500, but I would be delighted to spend less!
SETUP:
OPTIONS CONSIDERED:
I am leaning heavily towards the sound bar, but don't want to give up too much sound quality.
Any experiences out there about these types of options?
SETUP:
- The TV is 65" plasma mounted above the fireplace.
- Pioneer elite SC-25
- Velodyne 12" sub behind couch
- Existing in-ceiling surround sound speakers in back of room
- There is room for a sound bar or center channel either on the mantle or above the TV.
- The room is 16' x 20' family room opening to kitchen & dining
- Wife has specified it must be low-profile, so thin on-wall or in wall are acceptable.
OPTIONS CONSIDERED:
- Definitive Mythos SSA-50 sound bar (use only LCR or use all 5 and use ceiling speakers to make 7.1 system)
- In wall Definitive UIW RLS III (but I have to pay a contractor to open the wall, cut the studs and frame out support for the center)
- On wall Definitive XTR-50
