Very happy with this machine, the brightness is perfect for my settings and blu ray and tv shows look great. One problem I have is particularily football games do not look good. 1)I don't know what the technical term is, maybe noise, possibly blur, but just seems to be a lot of pixelation during football games. It's not the cable or HD provider , I have a samsung 55c8000 and tried that and there are no issues....Is that just one of the weaknesses of this machine? It's almost like the "sports mode" has the moist noise, etc. when watching football...Like I said movies look great, just football does not look good which is dissappointing. 2) Also noticed eco mode does not appear to change my image at all which I know others have commented about. 3) this is my first projector, overall I am very happy.Is there anything I can do to make the picture more like my LED? I miss the glossy screen on the LED , just seems like the color saturation is much duller than a typical flatscreen. ON brighter notes, I never notice the fan noise and the brightness is even better than I anticipated... i've tried Art's calibration settings, etc., still have not found the sweet spot for sports...Any info is appreciated.
AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Panasonic PT ar100u thoughts and Issues
Featured Stories
Topics Discussed
- brandDenon
- brandELITE SCREENS
- categoryLED HDTV
- itemPanasonic Pt Ar100u Lcd Projector
- categoryProjectors
- categoryReceivers Amplifiers
- brandSamsung
Related Forum Threads
- Universal Remotes in Singapore/Hong Kong Last post on 4/14/13 at 9:03pm in Remote Control Area
- The Aviator - Sound is terribly low, picture quality sub-par? Last post on 6/20/12 at 3:26pm in Movies, Concerts, and Music Discussion
- Recommendations - 32" to 42" LED for bedroom with lots of light. Last post on 3/20/13 at 11:20am in LCD Flat Panel Displays
- Samsung 60" Ghosting Issue (UN60ES6500) Last post on 2/13/13 at 7:21am in LCD Flat Panel Displays
- Samsung UNxxEH6000 vs UNxxF6000 series (F6300?) Last post on 4/16/13 at 8:40pm in LCD Flat Panel Displays
Related Articles
Projectors 101: AVS’ Favorites
Edited on 10/5/12
- Innovative and Interactive LCD Projectors for Large Rooms
Edited on 9/11/12- Denon 2011 and 2012 AVR FAQ, Setup, and Troubleshooting Guide
Edited on 9/13/12Related Reviews
Gear mentioned in this thread:
post #2 of 78/31/12 at 8:14am- Mr.G
- Trader Feedback: 0
- Real Genius
- offline
- 2,386 Posts. Joined 1/2007
- Select All Posts By This User
Moose, if it really is pixelation then the problem is likely due to the length and quality of your HDMI cable, just because your Samsung looks fine doesn't mean that the quality of the signal reaching the AR100U is adequate. If it is noise try lowering the detail clarity on the 100. Sometimes blowing up the size of the picture (you don't mention your screen size) can amplify a problem you don't notice on a smaller HDTV. I have never used the 'sports mode' so I can't comment on that. Out of the box I went straight to 'Vivid Cinema' and haven't bothered to change it or even calibrate the projector so far. I have watched a few bits and pieces of pre-season football games and they look fine on my 100 but I don't use HDMI for cable TV. I use 40 feet of component cable from the cable box to the projector. But I do use 40 feet of HDMI cable from my Denon receiver for my Blu-ray player(s) and my WDTV Live streamer for Netflix/Hulu+/VUDU.
When you say that the AR100U looks flat and dull are you talking about a picture with ambient light or in a dark room? In a dark room although not a match for a plasma or LED HDTV the 100 looks great. If you are getting anything less than that something is wrong. If you're talking about watching the 100 with ambient light then that's normal. You don't mention the picture modes you're using other than 'sports mode'. I won't bother calibrating anything other than Rec709 and Cinema 1 for movies. Have you read through the AR100 thread? The eco-mode setting has been discussed there. Use the search feature on this forum.
Your post is very similar to posts from 'robzilla' back in April. Here's a link to that discussion.
http://www.avsforum.com/t/1358778/panasonic-pt-ar100-msrp-1-999-4000u-replacement-kind-of/630#post_21941174
http://www.avsforum.com/t/1358778/panasonic-pt-ar100-msrp-1-999-4000u-replacement-kind-ofI have 20 ft mediabridge HDMI's so it very well could be the problem, but I know others that use these and have no issues so a little dissapointing. I have Comcast/Xfinity cable. What I mean by dull, is that it just doesn't have the shine/sheen of my samsung. I guess I miss the glossy look that makes the colors really pop. I've trid all the picture modes, vivid cinema looks best, but again, the colors just don't pop as much as an LED. I have a 100" elite screen.post #4 of 79/5/12 at 8:36am- Mr.G
- Real Genius
- offline
Okay, I think I understand now. Did you happen to look at the first link I provided? It was a comparison shot of my 50" Panasonic plasma HDTV and the AR100U - side by side. Is your picture comparable? You have to remember that your Samsung LED is directly transmitting light versus the AR100U where its light is reflected back from your Elite screen which I'm assuming has 1.1 gain material. I was reading the Amazon reviews of the Mediabridge 25 foot HDMI cables and although most buyers are happy with them there were several reviews where the cables failed completely or didn't work as specified. You can always swap the HDMI cable with one from Monoprice for as little as $18 plus shipping and compare the difference - if any.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10240post #5 of 79/17/12 at 10:10pmpost #6 of 79/18/12 at 12:38pm- greg1292
- Trader Feedback: +3
- offline
- 900 Posts. Joined 10/2004
Quote:Da-lite HP screen will give you the pop and then some. http://www.avsforum.com/t/773065/high-power-a-review-part-1 a good readOriginally Posted by Moose4242
indeed!post #7 of 710/9/12 at 10:07amReturn HomeBack to Forum: Digital Projectors - Under $3,000 USD MSRP- Panasonic PT ar100u thoughts and Issues
AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Panasonic PT ar100u thoughts and Issues - Innovative and Interactive LCD Projectors for Large Rooms
Currently, there are 1181 Active Users
(209 Members and 972 Guests)
Recent Discussions
- › NEW Unofficial Blu-ray Audio and Video Specifications Thread 46 seconds ago
- › MITSUBISHI HC5, new 3D SXRD projector based on HC9000 2500 euros 2 minutes ago
- › LG PA75U -Anybody else own one of LG's Abandoned Children? 2 minutes ago
- › Official Panasonic TC-PxxST60 Series thread 2 minutes ago
- › Sony HW50 / BenQ W7000 / Epson 5020 / JVC RS55 / JVC RS 46 / JVC... 2 minutes ago
- › New speakers. 4 minutes ago
- › Picked out my set-up, let me know if I am making a good choice. 5 minutes ago
- › 4k by 2k or Quad HD...lots of rumors? thoughts? 5 minutes ago
- › Official Chase Home Theater Owners Thread 6 minutes ago
- › Official OPPO BDP-105 Owner's Thread 7 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
