AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › TC-P50UT50 Black levels
post #1 of 4
I'm purchasing a tc-p50ut50 from bestbuy next week, I would like to know the difference in black levels for the UT50 when compared to the panasonic g10 plasma, I was aware of the rising blacks issue on the 2010 panasonic plasmas. I know the UT50s blacks will be better than a G10s blacks with 500 hours in because of its rising blacks. Are the blacks on the UT50 better than the blacks of the G10 when the G10 was in its prime?
post #2 of 4
Yes, the blacks are WAY better than even a new G10.
post #3 of 4
Wouldn't the P50ST50's black levels appear deeper than the P50UT50's as it has a better glare filter?
post #4 of 4
not according to PathofNeo, maybe a very bright room, dont think its worth the extra money so i'm going for the UT50
