So after years of using a HTIB setup (Logitech Z-5500) I am in the market for a real stand alone receiver.
The main reasons I want a receiver are: more connectivity options, better upgrade-ability and hopefully in the long run better sound.
I am an avid gamer so this receiver would be used primarily for playing games, though I also watch a blu-ray or dvd every so often.
It will be hooked up to a Wii and a PS3; now I am not sure if every receiver supports it, but I would like for it to support Dolby Pro Logic 2 since the Wii has no real discrete audio support and for my PS3 at least DD/DTS and LPCM. In the future it will probably be connected to a Wii U as well (also a motivation to get a receiver since it will only support LPCM audio through HDMI).
My plan is to re-use my 5 satellite speakers from my Logitech Z-5500 for now as to spread out my purchases a bit more, but the plan is to eventually also get 5 new speakers essentially replacing my whole 5.1 setup.
I will need a new subwoofer since the one that comes with the Z-5500 is proprietary and doesn't sound that great anyway (really boomy and the bass is not very tight).
Any suggestions on recommended speaker bundles and subwoofers are appreciated.
The space I will be using it in is approximately 5 x 5 meters so it is a decently sized room, I don't know if that is helpful information for choosing a receiver or that it only applies for determining which speakers are suitable for the room but I thought I should mention it just to be sure.
Now I have done some research on different receivers and terminology (tested frequency range, impedance, THD, etc) and have heard about the trouble of finding honest receiver specs.
That is why I would like opinions on good receivers since just looking at the receiver specs isn't getting me anywhere.
I have looked at several receivers and I was thinking about getting the Yamaha RX-V373.
Though I am not sure if it has a decent amount of power since the way they measured power is not RMS and only on the 1KHz frequency and of course the fact that I am not very familiar with receivers since I never actually owned one.
Any opinions on this receiver or a better one for ideally around 300 euros would be great; I would like to keep my purchase under 400 euros since I also will need to buy a new subwoofer.
