AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Bias lighting for 64 inch Samsung Plasma
post #1 of 6
Can anyone recommend a product. Nothing too costly.
I found this, but it's too small:
http://www.amazon.com/LED-Backlight-Flatscreen-Wall-Mount/dp/B00390L5SE/ref=sr_1_4?ie=UTF8&qid=1346508478&sr=8-4&keywords=bias+lighting
post #2 of 6
We simply use a small - maybe 15" - supposedly "daylight" tube lamp behind our 60" set - and I actually have a couple of bent metal "reflectors" ovher that, partially to help direct the light & partially to REDUCE the amount of light that is visible.
post #3 of 6
I have the LED strip kit from barlighting.com Mutliple colors and wireless remote. LOVE, LOVE LOVE it! I also have the LED disk kit for the tv cabinet.
post #4 of 6
I use six undercounter soft-white flourescents that I got for <$15.00 each from Menards. I used 2" velcro "sticky-back" to attach them. I have them connected in series, and I use a foot-switch to turn it on and off. It works well.
post #5 of 6
Bias lighting should be as close to 6500K as possible, otherwise the light will affect the color of the set.
Ideal Lume is what most people use.
post #6 of 6
'D65 Video Bias Lighting- Fundamental Theory And Practice'
http://www.avsforum.com/avs-vb/showthread.php?t=1162578
