AVS › AVS Forum › Video Components › Home Theater Computers › TV-focused HTPC
TV-focused HTPC - Page 2
post #31 of 34
Originally Posted by avken View Post
Really unfortunate that the Duet got discontinued with no replacement. I can't find the AVerMedia Duet card for less than $80. At that price, I think I will go with the Hauppauge 2250 unless someone knows of a cheap source for the Duet.
Depending on how I searched ebay I got different results. Here's some used Duets for $48 or make offer, & free shipping.
http://www.ebay.com/itm/Avermedia-Duet-ATSC-QAM-Dual-TV-Tuner-A188-/251144210899?pt=US_Video_Capture_TV_Tuner_Cards&hash=item3a795c89d3
post #32 of 34
I have 2 Duets I'm using as well and I purchased them both from eBay and they have been working great. I'm watching the Cowboys vs Giants on OTA right now! smile.gif
post #33 of 34
Yeah, the HDHomerun makes sense for the Mac or if you're not comfortable opening up a PC. So with multiple tv's, do you need a PC hooked up to each in order to access the HDHomerun content? ...
Well, you need something to access the tuners or DVR recordings. I believe an Xbox 360 works. Due to my home network setup, I'm not able to confirm anything, but the xbox is mecia center extender. So, you don't necessarily need a pc. That's more about what need the attached box to do on that TV. I like to watch live sports that are blacked out in my area. This requires the use of VPN and there are only so many devices that I can use with a VPN such as PC or smart mobile device.
Good point about the PPV and VOD. It's hard to get that ideal setup when the cable companies prefer to rent you their boxes. ...
I have a coworker who use to work at Comcast, and their goal was to have at least one box in every home. They're may be some issue with being able to control the PPV or VOD. Personally, I think they just want to rent the box.
post #34 of 34
Originally Posted by MKANET View Post
You dont have the 29/59 bug. Many people who see unexplained video stutter or other types of flicker to the "29/59" bug without even knowing what the 29/59 bug is. The "real" 29/59 bug is caused by american premium television networks encoding their TV shows and movies in a weird mixed soft/hard telecined mode (causing the 29/59 frame-rate flip-flop. Many common modern display cards; especially Nviidia, can't handle on-the-fly switching without adding a stuttering video effect during soft-telecine scenes. Non-premium TV channels such as NBC and CBS don't do this; so, even very old display cards can handle deinterlacing this content.
Having said that, if you have a HDTV hooked up to it, you should look into the stuttering that can be caused by framerate interpolation trying to synch up to your display card's timings. Reclock is a great utility that can help video from stuttering.
The 29/59 bug sThat's related to premium TV channels only; which you can't get without a cable card tuner and cableTV subscription to that channel.
I have come across a couple postings such as this where people are having 29/59 problems on CBS, and in this case also on NBC. There’s a couple people on this page with such problems.
http://experts.windows.com/frms/windows_entertainment_and_connected_home/f/114/p/87594/497103.aspx
Maybe this is not the “real” 29/59 bug, I have no idea. But it is a problem.
I just installed an HD 6450 video card & after installing the latest driver my problem went away. Using WMC7 and 4-1-1-Info, it indicates the frame rate still jumps, however the picture does not.
