I'm in dire need of assistance so any input would be appreciated. I am getting a bar installed and have the current setup:
Sherwood New Castle R-865 (yes I know...it's a bit out dated)
Connected to it is a HD-Cable Box, DVD Player, and DLP Projector
What I would like to do is be able to share the components with the new TV at the bar.
My question... how (if possible) can I run cables to the tv at the bar without having to point the remote at the components(across the room) and has the least amount of signal loss?
Hardware suggestions, model numbers, etc. Would be helpful. The only options I see are either to split the monitor out(component) to the projector and the new tv(which I'd still need to run some kind of ir receiver...any suggestions?) or run cables using room 2 option but I would still need an ir receiver near the new tv AND it is composite out and not component.
Again, any feedback is appreciated.
