AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › HDMI and IR in another room
post #1 of 3
I have a Tivo that I want hooked up in another another room.
Right now I have it hooked to a older TV via Component and I would like to hook the HDMI up to a LCD panel in another room. If I had t guess the length of the run I would say it was 40 feet. I'm not too concerned about what method, but was thinking HDMI over CAT5e/6 w/ IR also. I don't know the quality is with this method or if there is a better method.
Price wise, I'm pretty much ok up to a $500 solution if it is more future proof so I could extend it out due to moving or something....
I would also look at a more expensive future-proof true distribution method that would allow me to move my A/V components toward a true long term solution.
One thing to point out is I have conduit throughout the house so I can pull cables where needed (3/4" conduit).
Thoughts?
post #2 of 3
Found the main thread. They really need stickies...
post #3 of 3
The Monoprice HDBaseT solution would get you everything for under $200 using a single cat5e. That would probably be the most trouble-free solution.
Jeff
  Back to Forum: Home A/V Distribution
