AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Do some LED TV's do this? Flicker of tv logo on HD channels
post #1 of 3
I have 2 Samsung UN46EH6000 LED tv's.
Automotion set to off.
I notice on certain HD channels (never non HD), that if there is text on bottom left or right bottom of screen, that text or logo will flicker.
Such text or logo may be the name of the show, next show coming up or the logo of the channel
Am watching Breaking Bad right bow and the AMC HD logo has a slight waver to it.
Notice this on on some other channels too but never on non hd.
Thanks for any input
post #2 of 3
Lcd motion performance at work biggrin.gif I see it all the time on fine lines on lcds, motion improvement settings are there to mitigate it, if you have it turned of then you'll likely see it on alot of lcds.
post #3 of 3
I made a mistake. Automotion was set to custom, i set it to off and the flicker of logo and text at bottom of screen went away
Pc
