This is my new folded horn design. I needed feed back to see if I need to change anything. I am about half way on 2 of the cabinets. I got two eminence 18's on the way now. to put in them. each one will stand about 4 feet high. I got the dimensions out in the shop. I can get them to someone if they need them. Right now I have 2 Peavey black widows in single peavey cabinets and I am looking for more bass. the two fifthteen do ok on kick drum and mids but just enough for tonal bass. hopefully this works great. I had priced some new cabinets but they just cost to much compared to what it would cost to build them for. I can build and load 3 of these with 18's for the price of one of those cerwin vegas. So do you all think it is a good design? I used google sketchup to make the blue print designs the best I could. At the top where the access panel for the woofer it will be double ply of 3/4" MDF. Every thing glued and screwed and I'll coat the whole cabinet with armor plate.
My New Folded Horn Design!!!
AVS Top Picks
post #2 of 31
9/3/12 at 1:26am
post #3 of 31
9/3/12 at 5:59am
post #6 of 31
9/3/12 at 7:15am
post #7 of 31
9/3/12 at 7:21am
post #12 of 31
9/3/12 at 7:57am
post #15 of 31
9/3/12 at 8:12am
post #16 of 31
9/3/12 at 8:24am
post #18 of 31
9/3/12 at 8:58am
post #19 of 31
9/3/12 at 9:25am
post #20 of 31
9/3/12 at 12:17pm
post #21 of 31
9/3/12 at 1:58pm
post #22 of 31
9/3/12 at 2:06pm
post #23 of 31
9/3/12 at 2:12pm
post #24 of 31
9/3/12 at 2:14pm
post #25 of 31
9/3/12 at 4:52pm
post #26 of 31
9/3/12 at 6:47pm
post #29 of 31
12/22/12 at 5:27am
post #30 of 31
12/22/12 at 6:30am
I'm just here to observe & learn.
