AVS › AVS Forum › Audio › Home Theater In A Box › Onkyo TX-SR606 HTIB receiver problems whats the best option??
post #1 of 3
Hello,
Long time reader first post...I have an Onkyo TX-SR606 HTIB system and I believe the daughter board on the receiver is busted. I can not turn the system off cause then it takes an incredibly long time for a signal to even be seen and that is just for one of the inputs. On the other inputs, it is almost impossible to get a signal without constantly restarting the system over and over again or waiting a really long time. It has become pretty much unusable.
I dont know how much it might cost to fix this, would it be worth looking into a new/better receiver? If so, what do I do about the existing speakers? I'm not sure which other receiver would be best compatible. Thanks for the input.
post #2 of 3
Originally Posted by essg88 View Post
Hello,
Sounds like your HDMI board. This is a known issue with this receiver, bad caps on the board. Call Onkyo, AFAIK, they're still replacing them for free.
post #3 of 3
Oh wow, that would be great. I will give them a call tomorrow. Thanks for the info, I'll update with their response.
  Back to Forum: Home Theater In A Box
