I'm in the market for a new antenna after the cat chewed the wire on the old one.
The antenna I used to have was just a cheap $15.00 RCA digital flat one from Wal-Mart...
http://www.walmart.com/ip/RCA-Digital-Flat-Antenna-made-for-DTV/10542272?findingMethod=rr
It worked ok but it needed to be constantly adjusted. I used to hang it out the window since the tv is near the bedroom window and it would lay out on the roof (room is on the second floor).
Today I bought a more expensive RCA antenna from Wal-Mart...
http://www.amazon.com/RCA-ANT1450BR-Multi-Directional-Amplified-Digital/dp/B001GE6T9A
Though this one is amplified I'm not even getting close to the same amount of channels I got with the older cheaper antenna. Maybe I'm not setting it up right. I've never used an amplified one so I don't know much about them.
Would I be better off getting the old antenna I have, sticking with the amplified one, or should I consider this other one that they have at Wal-Mart...
http://www.walmart.com/ip/RCA-Digital-Flat-Amplified-Antenna/10983718
It either needs to be from Wal-Mart, Radioshack or Best Buy, I need an Antenna for Wednesday so I can watch the Cowboys game.
I may be willing to get another one (from a website) but that one won't be here in time. So what I need is a temporary recommendation (sports bar isn't possible) for this weeks games. And then a long term suggestion.
The long term suggestion needs to be under $50.00.
Edited by Oedipus - 9/3/12 at 7:01pm
