I just moved into a new house with a finished basement - went out and bought a TV mount thinking it would be no problem to install as I've done a few of these before. Famous last words.
When I went looking for the studs, the studfinder is showing that they're 4" wide - my first thought was that the studfinder wasn't accurate, but it's a pretty nice black and decker with a brand new battery (one of the ones with a laser level too) - and the 4" wide reading is happening on all 3 walls that are built against the exterior (poured concrete foundation).
I cant tell exactly how they built the walls, but from the best I can tell it looks like they laid the studs sideways against the foundation, meaning I only have drywall + 1 and a half inches of stud to bolt the mount into before I hit concrete.
Has anyone come across this before? Not sure what my options are. I want to put a 60" in the room, but I haven't bought the TV yet, just wanted to get the mount up while I decide on a TV.
Football is starting way too soon though, so I need to get this figured out! Appreciate any help/thoughts.
