AVS › AVS Forum › Audio › Speakers › Room big enough for 7.1?
post #1 of 7
Hello everyone. Everyone on these forums has always been so helpful and I just wanted to say thank you ahead of time. I had plans for a big dedicated home theater room in a new home but some unforeseen circumstances have prevented that. Currently I have a room that is 14ft wide and 10 or 11 ft in length. Is this enough room to merit a 7.1 system? For some strange reason I am infatuated with the idea of having seven speakers. I currently have the introductory Andrew Jones Pioneer system powered by a Pioneer VSX521-k. I was going to buy two more bookshelves and a different receiver but want to get your opinion first. I could also buy a completely new system and leave the Pioneer system upstairs. Is 7.1 possible in this room? Any ideas on a different system on a 1k limit?
post #2 of 7
Depends on how the room is layed out. You typically want at least 4-6' or so from the back wall to the seating position. If your seating position is right up against the back wall, I would just stick with 5.1.
post #3 of 7
This room has the weirdest layout ever. It's 14ft in length, but when I hit 14ft there is a stair case that just goes straight up. It's an open floor plan so after the staircase there is a wall. So I could potentially stick the back speakers on the wall behind the staircase but they might now shoot directly towards my ear seeing the the staircase goes up and one of the speakers would basically not hit my ears. Bummer.
post #4 of 7
I don't think it is worth the effort based on your description. I would focus your budget on that new receiver, preferrably something with Audyssey MultiEQ or MultiEQ XT.
What are you using for a subwoofer?
post #5 of 7
I guess I also see all these 7.1 movies coming out in blu ray and my mouth waters. Feels like I'm missing out on something awesome.
post #6 of 7
I'm using the sub that came with the Pioneer package. Not the greatest but now that this move isn't going to happen, I have to upgrade equipment if 7.1 is not possible. Would you get a whole new system? Or just upgrade the sub and receiver? I love these pioneer speakers but sometimes I feel like there is something missing.
post #7 of 7
I think the biggest weak spot in your setup is your subwoofer. I would start there. Then get a receiver that has Audyssey MultiEQ then look into your main front speakers. This is not a cheap hobby and once you want more you realize there is a cost that goes along with it. That said, even what you have no is very superior to the built-in speakers that are typically found in TV's that most Americans use.
  Back to Forum: Speakers
