Originally Posted by
Glenee
Just some info for you. ARC (Auto Return Channel) will only pass 2.0 pcm or DD/DTS same as optical. Even if you have a Blu-Ray that is sending HD Codecs Via HDMI to the Display it will not pass those to the Yamaha YSP. To utilize the ability of the Yamaha to decode HD Codecs found on most Blu-Ray it has to be Fed directly from the Source VIA HDMI. So you will need to plug the BLU-RAY VIA HDMI Directly into the Yamaha to use it's full potential. If you are not watching Blu-Ray and desiring the HD Codecs the ARC will work out just fine for the other 90% of you viewing enjoyment.
The reason I put this up is to save you the frustration of why my Yamaha will not recognize the HD Codecs.
My theory is, If we understand the limitation of technology we can enjoy it more.
I learnt that this is a function of the sound output from the TV to the soundbar. I've been tweaking this (I'm a guy who loves his toys
) the last couple of days and I wanted to see, how I could get the 'Surround' LED to turn on on the soundbar.
This is what I've done:
All my HDMI inputs feed the soundbar and I use ARC to output audio from the TV to the soundbar.
1) Set the sound output from the 'Cable box' to surround instead of stereo. This will output the audio to DD or DTS, which basically turns the surround LED on the soundbar to orange.
2) Set the sound output from the 'XBox 360' to Dolby Digital 5.1, this will output the audio to DD which basically turns the surround LED on the soundbar to orange.
3) Set the sound output from the 'TV' (FYI my TV is a Sammy) to 'DD' or 'DTS' instead of 'PCM'. This will output the audio to DD or DTS, which basically turns the surround LED on the soundbar to orange.
Now I don't have a Blue Ray player
and based on the audio output codecs (of devices) connected to the soundbar, I'll never get the 'Surround' LED to turn blue on the soundbar. This was something that I happened to stumble upon when I was treaking the different setup menu options on the devices connected to the soundbar.
Another thing I'd like to point out is, choose the right decoders on the soundbar in case you're not using 'AUTO' for channel outputs.
Glenee
Amen!
