AVS › AVS Forum › Audio › Receivers, Amps, and Processors › What competes with Marantz sr7007?
post #1 of 2
Is it the best Or is the high priced denon the same product? Any others in the price range that compare. With this reciever would i need an amp as well? new here any help appreciated.
post #2 of 2
The comparable Denon model is the 3313CI which uses the same version of Audyssey MultEQ XT, whereas the 4311CI (and newer 4520CI) both use the more advanced version of Audyssey MultEQ XT32 which uses 32x more speaker control points and 4x more sub control points then does XT.
