I'm pretty new to the whole htpc and media streamer tech, so I'm wondering, when these media devices have issues with stuttering and audio drop outs, is it because they are being streamed from your local network and not from say an attached usb or internal hdd? I think so, but wanted to verify. I'm asking about the 3D iso's which I will start ripping once I find a discount or coupon for AnyDVD HD
I just want to make sure if I attach a drive to the media streamer, that it will not have any issues with playback at all, even at high bit rates for some 3D iso's.
If I decide to pickup a 2TB USB 3.0 or internal HDD and attach to the media streamer, when I rip the 3D iso's on my PC, will I be able to transfer the files from the PC to the USB or HDD on the media streamer? OR do you have to transfer them from your PC to the USB or HDD and then unplug and attach to the media streamer? I'm assuming you can just move the files from the PC to the USB or HDD attached to the media streamer if they're on the same local network, which for me is on a gigabit network with cat5E cabling.
Is it better to get a USB 3.0 drive vs an internal HDD? Which one is faster in transfer speeds b/c copying huge 3D iso's will probably take awhile. I guess USB 3.0 would be good b/c you can just unplug and plug into another media streamer if you have it. Now that I think about it, if you have a USB attached to the media and it had the scrapper to pull up artwork, etc., when you disconnect the USB and reattach it later, does it have to redownload all that info and if so, I guess it depends on how much content you have on how long it will take?
Also, when you all purchase from say Diamond Designs, do they ship right away or is there usually a backlog when new versions come out? Once I hear some reviews from you all, I'd like to purchase right away, and as of now, it's either the Mede8er 1000x3D or the PCH A400.
I just want to make sure if I attach a drive to the media streamer, that it will not have any issues with playback at all, even at high bit rates for some 3D iso's.If I decide to pickup a 2TB USB 3.0 or internal HDD and attach to the media streamer, when I rip the 3D iso's on my PC, will I be able to transfer the files from the PC to the USB or HDD on the media streamer? OR do you have to transfer them from your PC to the USB or HDD and then unplug and attach to the media streamer? I'm assuming you can just move the files from the PC to the USB or HDD attached to the media streamer if they're on the same local network, which for me is on a gigabit network with cat5E cabling.
