Originally Posted by
sotti
In the video display connection dialog, there are two entries. One is for the radiance CMS, the other is for the radiance 3D LUT.
Make sure you're connected to the 3D LUT version. You'll also want to use the "Color Cube " workflow to calibrate the cube.
I can't seem to find the correct setting to get the Color Cube LUT calibration started (Step 3)...
I'm in the Color Cube 3D LUT workflow, just finished Step 2 "Pre-Characterize Display" (all values pass) and when I click on the CALIBRATE CUBE LUT button the template jumps directly to Step 4, which I think is the 1D ramps...
Here's what I got configured:
Meter Settings Dialog Box: i1D3 using an i1Pro profile
Source Settings: Lumagen Radiance Series
Display Control: Lumagen Radiance Series 3D LUT - Config / CMS 0
Why is it skipping Step 3 ?
One things is odd though, under Step 1 in the Color Cube template > Image Processor Setup > I selected "Lumagen Radiance 3D LUT fw 090412 or later (RS-232)" but I cannot specify a 3D LUT memory slot...
- M
