AVS › AVS Forum › Display Devices › Display Calibration › Radiance 3D LUT (5x5x5 Cube) Calibration with CalMAN 5
Radiance 3D LUT (5x5x5 Cube) Calibration with CalMAN 5 - Page 17
post #481 of 544
Originally Posted by JimP View Post
What kind of patterns do the Lumagen processors generate to do the cube calibration? Field, window, APL small window, APL large window?
Lumagen's Window Pattern Size:
Medium Windows size: 11.11%
Small Windows size: 1.56%
post #482 of 544
There is an option it CalMAn that enables you to pick the size guy want it to use. Unfortunately it doesn't keep this setting and set it to your preferred size after you exit and later restart CaAN which is really annoying. A feature request to fix this was out in a while ago, so I'm hoping the next version willrber the preference.
post #483 of 544
Can I auto-calibrate my gamma to a higher value without messing up the color cube? In other words, do I have to re-do the color cube after a gamma change? I want to go from 2.0 to 2.2 or 2.4.
post #484 of 544
How would you change the gamma if not recalibrating?
You can just tweak things like the gamma factor in the radiance, but you'll be introducing error when you make those changes.
If you want it to be dead on, then you'll need to run through the process again doing both the grayscale ramps (where gamma is accurately established) and the Cube (which has to be cleared before you can calibrate the gamma).
post #485 of 544
Yep... that's what I thought. Makes total sense. Just wanted to be sure before I went through the process.
So the Lumagen Mini 3D has 10 slots I think? Can't I just use a new slot to keep my 2.0 calibration as long as I don't touch the projector's settings? I'd like a 2.0, 2.2 and 2.4 calibration available at the push of a button to see how they compare.
post #486 of 544
Yes that should work.
post #487 of 544
There are 8 CMS (0-7) slots.
post #488 of 544
Thanks. I'm only up to slot #3 on my current calibration and now I'm going to go back and recycle some of the earlier calibrations.
post #489 of 544
Here's a fairly big attachment showing my exploration of gamma calibration results. It looks pretty reasonable because the Radiance is making small changes to get my projector to a gamma of 2.4 after I tweaked the projector to get close. The first graph looks reasonable. But the second graph, a plot of the differences, is pretty rough. Is this measurement error showing up or something else? If what I'm looking at in the second graph isn't clear, gamma.jpg 188k .jpg file let me know and I can detail it.
post #490 of 544
To be honest, both graphs look poor to me... it's just the scale of the graphs that is different.
I would expect a much better results that that for accurate calibration frown.gif
post #491 of 544
I would agree, CalMAN doesn't leave a radiance with that kind of correction.
I think that is the user's manual calibration.
Notice, that's an excel doc and not CalMAN data.
post #492 of 544
Thanks, sotti. That data was transcribed from the DCC window after an automated calibration. It is possible to get raw data out of CalMAN to analyze myself without transcribing it?
post #493 of 544
Did you use gamma factor?
AutoCal only works when gamma factor is at 1.
I know lumagen frequently recomends using gamma factor as it's a continuous function and their grayscale point are implemented in piece wise liner.
Changing the gamma factor changes where the patterns line up with the control points.
post #494 of 544
Yes. The gamma factor is 1. I will look at the calibration data again after this most recent calibration when I get a chance.
post #495 of 544
There some new Drivers for those who got Lumagen Radiance from SpectraCAL and using the included CalMAN Certified USB to Serial Adapter for the connection.
FTDI VCP CDM 2.08.28 WHQL Certified (20-02-2013)
http://www.ftdichip.com/Drivers/VCP.htm
Release Fixes
- Fixed bug on close port for .NET Framework applications.
- Fixed problem on close port that caused some hubs to fail.
post #496 of 544
Hopefully someone can help a newbie out on a fist time calibration… I just bought the Calman 5/C6 combo and already have a Radiance mini with the most resent firmware. I have a JVC RS48 in a near cave like environment antique black tin ceiling, dark blue walls, dark gray soffit with a black diamond 2.39 126” screen. I have been through this thread and also the calman v5.1 software and have seen people discussing doing a 21 point grey scale first and then the 125 point auto cal. The auto cal seems to be easy enough to perform and I already have my brightness/contrast setting down using the avs pattern disk but I can’t seem to figure out how to add the 21 point grey scale calibration to the autocal workflow or run it before??? Any help and any other suggestions for my environment/projector screen combo would be great. I am still waiting on my usb to serial adapter, forgot to purchase it with the kit so maybe this will be cleared up when I get it tomorrow.
Thank you,
post #497 of 544
Use the Color Cube workflow.
post #498 of 544
And you'll need to make sure 21-point is also selected in CalMAN's Program Settings. It defaults to 10-point there. Otherwise, you'll get an error message when the grayscale portion starts.
post #499 of 544
It's not a problem in 5.1, we prompt at the start of AutoCal and make sure the points line up.
post #500 of 544
I guess the prompt is the "error message" I'm referring to...
post #501 of 544
No in CalMAN 5.1, any autocal procedure starts off with a prompt to let you pick the settings, and then updates the options to ensure AutoCal simply works.
The error message should only occur in 5.0 or 4.x, go grab CalMAN 5.1 it's a very good upgrade.
post #502 of 544
Unbelievably good!
post #503 of 544
I already have it, but have done only one calibration with it, just for fun. Because of my experience with the older versions and grayscale point mismatch, I just automatically changed the point settings before starting so didn't see the new prompt. Sorry for giving out old/bad info...
post #504 of 544
No sweat.
We are always trying to make CalMAN better, so we make changes. We knew that particular point was a huge pain for many users, so we changed it to try and smooth out the user experience.
post #505 of 544
sorry if my question is more common than Calman or Radiance related.
I run a Color Cube on my VT50 in THX mode with Calman 5.1 last weekend and the post calibrated greyscale and gamma was much much better than than with 5.04. Many thanks to Spectracal!
As I own a EU model I also tried to calibrate a more brighter picture mode, but the pre calibtrated gamma of all the bright modes are a mess and THX cinema bright room was best.
due to the big gamma corrections that needs to be made to get a gamma of 2.2, it ends with strong posterisation in dark movie scenes. So if I can not use the gamma correction factor, how to calibrate with such pre calibration results?
Can I compensate the pattern issue Sotti has mentioned when I use a corrected gamma target?
E.g. (real) gamma target should be 2.2, gamma correction factor of the Radiance is 1.3. Will I get a real 2.2 gamma by setting the target in Calman to 2.86 (2.2x1.3)? Or does this not work?
Edited by DrFaxe - 3/11/13 at 9:30am
post #506 of 544
No sweat.
But Operator Error is always present!
Saturday night AutoCal Grayscale, set to 21 Points, and then went downstairs to do something else. Came back up after a half hour, only to find I forgot to Click on OK! Duhh!
post #507 of 544
Well yea there is always that. My best one is forgetting to place the meter on the screen.
post #508 of 544
My best is forgetting to cut the lights in the theater. I do calibrations from the projection booth and I don't have a window into the theater. Lots of cursing and head-scratching before I finally went back in to check on the meter. Head-slap!
post #509 of 544
I would think this would be addressed best by manipulating the TV.
I've seen on the VT50 EU's that you need to turn it's gamma setting up to 2.4 to get a 2.2 gamma on the lowend.
Your idea's about tweaking the targets and gamma factor won't work, it would just make a mess.
post #510 of 544
Hi Sotti,
thanks for reply. But in THX mode You can't tweak gamma, no such setting. In the other modes You can set gamma up to 2.6, but it will not get any better than the screenshot is showing. Gamma still much too low. Think I will stuck in the THX cinema mode, the only one with acceptable brightness and accuracy, with 100 nits (only) if no one has some other ideas. EU models really suck...
