Hi everyone. Fall is coming so I'm going to get back on my build. Next is the HVAC so it is in place and I will work around it then. I know this is one of the weakest links if not done right so I have a question. The HVAC will be for the theatre and the rest of the basement. Zone 3 of the house.
I don't have the room for a full soffit to run the flex in so I'm going to make mufflers up in the joists for the supplies and returns. About 4' will be run in soffit but the majority will be up in the joists. My question is the correct building on them.
My plan is:
1. line the top of the joists and the sides of the joists with DD.
2. what do i do with the bottom side? does the ceiling DD act as the fourth side of the muffler so I would bring the sides of the muffler down to line up with the channel on the ceiling? OR do I need my own DD bottom side to complete the 4 sides of the muffler? this second way seemed very sound but I didn't know if I would have some kind of triple leaf going on if there is a gap between the underside of the muffler and the finished DD ceiling on the channel?
3. Finally I'm going to use metal collars for the transition from the ceiling DD into the soffit where about 4' of soffit will continue. That will give me a tight transition. My question is the other end going back towards the main trunks where the flex will be just in the joists without muffler. where the muffler ends. can I just end my walls of muffler or do i need to bring DD down to pretty much make a complete box or by that point will the sound be controlled enough that the muffler DD stop and the flex continues back to the main trunk lines.
Thanks so much! Very sorry if this is wordy. I'm at work and didn't have time to do a drawing. PLus it wouldn't be good anyway.
jimi
My plan is:
jimi
