Hi all,
I'm in the process of setting up a small home theater in the basement of my new home. I have a projector mounted (Epson 8350) which I'm currently displaying on a painted wall. My wife loves the current size (120 diagonal) and does not want it any smaller. However, the projection wall is only 11'5" or 137 inches wide. Given some of the measurments of total screen size that I've been seeing (ex., Jamestown 120 is 111 wide including frame), I'm thinking that 120 might be too big for the wall. My speakers (BIC Acoustech PL-76 fronts with PL-26 center) would probably block part of the screen if someone was sitting at an angle to the screen.
Is there a calculator that helps one determine the max screen size for a given wall?
Any thoughts would be greatly appreciated. Let me know if more information about the set up is needed.
thanks,
Erik
thanks,
Erik
