AVS › AVS Forum › Audio › Speakers › Better front stage than B&W N801 and NHTM1 for $9k including amps?
Better front stage than B&W N801 and NHTM1 for $9k including amps? - Page 2
post #31 of 32
Mktheater I've read through your whole thread and am very impressed. Do you have a link to the exact parts of your dr200's? I've been to the website but can't quite figure out what parts you used. You also mentioned that your current setup was a bit harsh in the high end and were considering replacing with ribbons? I am a big fan of DIY so the dr's really appeal to me, but I am particularly bothered by harsh high end. Where would you say the sho-10s are deficient to the dr's?
post #32 of 32
The DR's were made to go with tuba and or Titan subs so their low end drops off faster than regular speakers. I wanted to use the DR's as tops and my 12x12 high excursion sub system as the bottom. In order to this correctly is to have a crossover at 200hz or EQ the DR's properly to match. They only sound shrill if the tweeters dominant the response. I use THX processor which has one crossover, 80hz! No matter what I either needed the titans or tubas or the DR's from 200hz and up would dominate the 80-200hz range and it sounds very sharp this way. Fine at low levels but once you turn it up it is too much. I EQ'd mine to be flat to 80hz and now I have Midbass which makes them sound balanced and not harsh at all. Proper integration and EQ is a must for these. I love my arrays!
  Back to Forum: Speakers
