Hi all,
Long story short I was flooded due to Hurrican Issac. It took out most of my Media room
The only thing I have to work with is the Projector (720P it was scheduled for a upgrade but storm hit,) My fixed 102" screen, 37" TV/Monitor and my Computer. I have my 7.1 reciever but due to wires I think im going to try something different. Working with ~ 300 sq/feet 11.5x22.5 or so.
Everything else is gone below 6" (Pics in sig).
I think I will go with a red/burgundy color with the blue for two tone.
Thinking a Sound Bar and Sub woofer. Much easier to move if needed(never flooded in my area before) and less wires.
AV cabinet for Modem, Router, Battery backup.
New Desk, Bed, Carpet,
My goal it to make items MUCH easier to move at a moments notice or have it setting up higher then I did with previous items.
Make the look nicer then it was before with out going overboard. Wire the house ,since a lot will be tore up ,to rid myself of wirelss connections.
Getting Ideas for a budget. With no net access unless at work this may take a while. Cable modem was in the Media room.
Suggestions welcomed but I will try to keep is simple.
Edited by Wytchone - 9/20/12 at 5:04pm
