AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Question on multiple tv sources
post #1 of 4
Hi everyone;
I am consulting on a home automation project, and we are nearing completion. The system we chose is the Elan G! system.
The house has about 10 TVs, and 5 TV sources (Motorolla DCX3400 cable boxes). Any TV can connect to any of the 5 sources.
We were trying it out the other day and we realized that if someone is watching TV on source 1, and then someone in another room starts watching on Source 1 as well, but then decides to change the channel - it changes for the first user as well! The reason we set it up with 5 TV input sources is that we wanted everyone to be able to watch what they want. The Elan installer is telling us too bad, that's how it is. But, I think there should be a way for the system to not let anyone else change the channel if the first user has already powered on. Any thoughts? Do other systems such as Control4 have the same issue?
thanks,
Jonathan
post #2 of 4
Label each of the cable boxes with someone's name etc. (on the GUIs). Then each member of the household will know which box to choose.
Another option is to "hide" certain boxes in certain rooms/zones. (The kid's don't necessarily need to see what Mom & Dad are watching etc.) I assume G! has this capability; I know Control4 does.
post #3 of 4
Oh, thank you. So the behavior is consistent and expected? (I'm assuming so).
cheers,
Jonathan
post #4 of 4
Yes.
  Back to Forum: Home A/V Distribution
