AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › wall mounting panasonic tc-p54s1
post #1 of 2
I am mounting my panasonic tc-p54s1 on the wall and can't figure out which holes on the back of the tv I am supposed to attach the bracket to? I have searched this forum and google but have found no answers. There are 4 screws on the back spaced about 12 inches vertically and 19 3/4 inches horizontally apart. Are these the right screws to take out and attach my bracket to? The only other screws are towards the bottom where the current pedestal stand is attached. Thanks.
post #2 of 2
On my 54G10 there's 4 large head plastic phillips head screws that you can take out and inside are metal inserts for your mounting screws. There's nothing else on the back like them so that should be it. Make sure your screws aren't too long so you don't go through the panel or a board. I'd gently insert the screws without the mount and make sure they go below the installed height if the mount were there, if not use spacers/washers or shorter bolts. G/L
