Edited by MellowVelo - 11/2/12 at 3:38pm
Featured Stories
Topics Discussed
- categoryBlu Ray Players
- brandOPPO
- itemOppo Bdp 103 3d Blu Ray Player
- itemOppo Bdp 105 Blu Ray Player
Related Forum Threads
- Disappointed in the Oppo BD-105 Last post on 4/12/13 at 11:38pm in Blu-ray Players
- PIONEER ELITE BDP-09 Last post on 3/16/13 at 8:29pm in Blu-ray Players
- Question about an oppo blu ray player Last post on 3/3/13 at 9:36am in Blu-ray Players
- OPPO BDP-105 vs Sony XA7ES for 2 channel audio question Last post on 4/11/13 at 4:51am in Blu-ray Players
- Are 4,5,6 year & older BD players still receiving firmware updates? Last post on 2/24/13 at 12:41pm in Blu-ray Players
Related Reviews
Official OPPO BDP-103/BDP-105 Anticipation Thread - Page 68
Gear mentioned in this thread:
- dmusoke
- Trader Feedback: 0
- offline
- 2,027 Posts. Joined 7/2009
- Select All Posts By This User
- dmusoke
- offline
A while back, i had some reservations(Nah! my very own expert knowledge
!) on the possibility of extra heat being generated into the 2-CH board because the video board was directly underneath the stereo. They respondedas follows:
We have done extensive testing on the thermal properties inside of the player, and we have made some design changes to ensure that a fan was not required and passive cooling would not interfere with the operation or audio characteristics of the player.
The first thing we did was make the player taller. The player is now 2.5U without feet, a half U larger than the BDP-95. The increased height allows for more distance to exist between the components, which greatly reduces the overall ambient temperature inside of the chassis.
The second thing we did was split the audio boards and offset their height. This allows air to flow between the two boards rather than getting stuck between the audio board and the mainboard.
The final thing we did was add vents. There are vents on the top cover of the player and a row of vents on the back panel, right above the stereo audio board.
Best Regards,
Customer Service
OPPO Digital, Inc.
2629B Terminal Blvd.
Mountain View, CA 94043
Service@oppodigital.com
Tel: 650-961-1118
Fax: 650-961-1119
- bakerwi
- Trader Feedback: +3
- offline
- 2,659 Posts. Joined 7/2008
Coris,
Do you modify all your components if possible?
Edited by bakerwi - 11/2/12 at 4:44pm
- bakerwi
- offline
- OtherSongs
- Great Audio
- offline
- 1,655 Posts. Joined 1/2009
A while back, i had some reservations(Nah! my very own expert knowledge:D !) on the possibility of extra heat being generated into the 2-CH board because the video board was directly underneath the stereo. They respondedas follows: ...
We have done extensive testing on the thermal properties inside of the player, ...and we have made some design changes to ensure that a fan was not required and passive cooling would not interfere with the operation or audio characteristics of the player.
The end result is a player which runs cooler and more efficient than the BDP-95.
Customer Service OPPO Digital, Inc.
Well there's a statement that finally has positive merit in favor or the 105 with regard to a possible heat issue of the 105 player.
Meaning that heat is likely not an issue for the 105 player; but still waiting to hear from actual real owners.
- Torqdog
- Audio Junkie
- offline
- 956 Posts. Joined 5/2010
I believe (and hope) the long and detailed e-mail below from Oppo will silence all squabbling regarding the DAC configuration design choices for the new 105.
- Bob Pariseau
- Read the FAQ!
- offline
- 24,271 Posts. Joined 7/2004
I'm not an actual real owner -- I just play one on TV. But I've deliberately set up my 105 in a semi-enclosed space to see if I could generate any heat related problems. This is a wooden console shelf space, closed by a door in the front and open in the back. There's a couple inches side wall clearance on either side and about 4 inches clearance above. The opening in the back is reduced a couple inches by a structural support across the back top of the opening.
I use a remote sensing thermometer periodically to see what's going on inside that space -- e.g., measuring the temperature increase of the inside surface above the player.
This is not a formal thermal analysis of course, but it works for me.
My results are simple. In this configuration the player's heat is being dissipated adequately and I've found no operational or quality problems which are due to heat, even after many hours of continuous use. This is with HDMI, with multi-channel Analog, and with the Headphone output.
--Bob
- OtherSongs
- Great Audio
- offline
Amusing.
Bob, I think well of you and neuromancer and rdgrimes and others in this thread.
I've removed heat concerns from my list of possible concerns of 105 player.
FWIW I'd not been aware of the venting built into the 105 case; you might stress that to others with concerns with heat buildup within the 105 player due to it not having a fan.
- dmusoke
- offline
Y'all are very welcome
! My posts came out of my extreme curiosity in its internal design details and answers were very few and understandably the beta-testers weren't going to reveal anything as they were under strict NDA rules. Once one burning question finally got answered then five more urgent ones popped up and the inquiry cycle repeats! So i began peppering Oppo and was suprised and grateful that they were patient and eager to answer my many questions.
Y'all are very welcome:) ! My posts came out of my extreme curiosity in its internal design details and answers were very few and understandably the beta-testers weren't going to reveal anything as they were under strict NDA rules. Once one burning question finally got answered then five more urgent ones popped up and the inquiry cycle repeats! So i began peppering Oppo and was suprised and grateful that they were patient and eager to answer my many questions.
We can nominate/elect you as our spokesman in relation with Oppo...
Good job!
- dmusoke
- offline
... And for those who wondered by the ESATA port was removed from the 103/105, Oppo's answer was:
" ... eSATA was removed from the player as we found the read performance to be substandard and the lack of hot swap capabilities lowered the utility of the interface."
- dmusoke
- offline
I guess Oppo will come again with an correction for this answer... This statement here is fully wrong. The read capabilities of the eSATA port are substantial better than USB one. Faster and and lower jitter (less corrections on the way...) than USB. No interface/speed conversion SATA - USB needed. eSATA is hot swap also... This is actually the meaning of an eSATA port - hot swap!
One may find out if the new upgraded processor have actually capability for eSATA port. If yes, then removing of this input is unfortunate. If no, then is not so much to be done... I suspect the first alternative is positive...
I have to remark that it were some contradictory answers from Oppo in the last time:
AC coupling? Yes all our players are/were AC coupled... Wait a minute.. NO!
DAC channels allocation? .... and 2 channels goes to the GND... Wait a minute... NO!
eSATA hot swap capabilities? No, not hot swat capabilities... (correction to come...)
Edited by Coris - 11/3/12 at 2:11am
- scanspeak
- David G
- offline
- 109 Posts. Joined 12/2006
I have had my 103 on for hours playing all kinds of different discs and it hardly gets warm at all. The 93 did not have a fan or cooling slots as well and I never read of any heat related issues with it.
Bill
- JonStatt
- offline
- 1,890 Posts. Joined 8/2001
- petetherock
- offline
- 890 Posts. Joined 6/2006
- rdgrimes
- Oppo Beta Group
- offline
- 14,804 Posts. Joined 3/2004
Sad for those with ESATA based drives who would like to buy these new players. They are out of luck, unless they buy external esata-to-usb converters which could have the possibility of complicating things further. I also thought the sustained data rates for ESATA were faster than USB 2.0?
I don't think Oppo was talking about speed. The controller chips for combined eSATA-USB cost more and tend to have issues. There were more than a few examples of incompatibility with external HDDs, unexpected issues, lack of port multiplying for multi-drive enclosures, etc. Oppo was able to offer more USB ports at the same price point, and eSATA's speed advantage has no value to a media player. IOW, not worth the trouble from either a performance standpoint or a customer support standpoint.
- wmcclain
- Bill McClain
- offline
- 13,988 Posts. Joined 5/2006
I haven't heard of that being tested, but it should work. Once the A/V is on the wire the player shouldn't care about the source.
The HD DVD player would have to produce audio the OPPO supports over HDMI. That means no DTS HD or Dolby TrueHD streamed. The source would have to covert those to LPCM or provide core tracks instead.
-Bill
tower, with the USB port connected to the computer across the room and the eSATA conneted to the BDP-95 below it. This allows
me to load movies from the computer for watching through the BDP-95 and also occasionally watch movies on the computer,
using VLC. This is one of my concerns with upgrading to the BDP-105. (As an aside: I am not sure why the BDP-95 eSATA
port does not support hot swapping. I know nothing about the player internals and could be wrong, but suspect this feature
could have been implemented fairly easily.)
Another concern has to do with Cinavia that the BDP-105 is infected with. I do not keep DVDs and Blu-rays discs next to the
system. They are safely stored in the basement, in nice cardboard boxes. They were played just once, converted to MKV files
and stored on the HDD. This arrangement offers several advantages (for me). First, it saves me the physical space for disks
that I don't really have. Second, all movies are available from the comfort of my sofa. Third (and this is a huge one), I am not
bothered by trailers, commercials and the rest of the garbage -- these are all removed before reaching the HDD.
A final half concern is the degradation of SPDIF inputs to 96KHz. In effect, this means that the player does not have usable
(for me) SPDIF inputs. I would want those, since the eSATA port is gone.
I am a bit surprised no one else seems to be concerned with the above.
-- Ron
- JonStatt
- offline
-Bill
I still have about 30 or so HD DVDs which I don't want to part with, and the Toshiba player as far as I understand does indeed decode TrueHD etc to LPCM over HDMI. So it "should" be okay. It means I can eliminate my 5.1 analogue switcher and a bunch of cables at the same time
- JazzGuyy
- offline
- 2,234 Posts. Joined 4/2002
OTOH, the SATA port -- as troublesome as it is -- was really useful. I have an eSATA/USB HDD sitting on top of the equipment
-- Ron
If you read through this whole thread and the one for the 103, you will see that these topics have been thoroughly discussed.
- Bob Pariseau
- Read the FAQ!
- offline
-- Ron
The USB DAC and the two HDMI Inputs on the 105 are all capable of 192KHz LPCM 2.0.
Since there are only a handful of discs shipped at the moment bearing the Cinavia watermark, odds are the vast majority of your current collection will be unaffected by Cinavia. For the future, we'll have to see.
Somehow, I think someone clever enough to figure out your eSATA/USB combo drive setup will be able to figure out a dual USB solution -- presuming you can't just turn it around and run the eSATA side to your computer. Just another of the little challenges that come with upgrading.
--Bob
- rdgrimes
- Oppo Beta Group
- offline
I wonder if you're failing to consider that with SMB support, its possible you don't need to connect any HDD to the Oppo at all.
Then Cinavia is of no concern to you at all, at least not yet.
-- Ron
Not sure what you would need to use the SPDIF input for, what device do you have with support for 24/192 output over SPDIF? Again consider the SMB support in the player.
- bakerwi
- offline
I don't know of any other manufacturer that would taken the time to answer such questions let alone in such detail. Oppo was really under no obligation to discuss (justify) their design coniderations and the fact that some actaully challenged their design as though no thought had went into the BDP-105.
- bakerwi
- offline
I meant to say transports. Sorry about that!
And I agree that sometimes things can be made better but of course at a price. Modders seem to like Oppo products in this manner, but I am glad that Oppo puts out a solid product at fair price and those who want to get more out of it can do so at their own expense.
- Brian-HD
- offline
- 2,137 Posts. Joined 1/2008
It's internet company.
- Official OPPO BDP-103/BDP-105 Anticipation Thread
Recent Discussions
- › Energy 5.1 Home Theater System $300 1 second ago
- › Picked out my set-up, let me know if I am making a good choice. 15 seconds ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 22 seconds ago
- › The Voice, Season 4, March 25th, 2013, NBC HD 26 seconds ago
- › Power Sound Audio Discussion Thread! 58 seconds ago
- › Bass that can be felt? 1 minute ago
- › 'Revolution' on NBC 1 minute ago
- › Panasonic ST60 vs. Samsung F5500 2 minutes ago
- › /// Reference 2: Blu-Ray Demo Disc (BD9s & BD50) \\\ 2 minutes ago
- › Microsoft fires the first shot in the "NEXT" generation.... 2 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
