-- Ron
Featured Stories
Topics Discussed
- categoryBlu Ray Players
- brandOPPO
- itemOppo Bdp 103 3d Blu Ray Player
- itemOppo Bdp 105 Blu Ray Player
Related Forum Threads
- Disappointed in the Oppo BD-105 Last post on 4/12/13 at 11:38pm in Blu-ray Players
- PIONEER ELITE BDP-09 Last post on 3/16/13 at 8:29pm in Blu-ray Players
- Question about an oppo blu ray player Last post on 3/3/13 at 9:36am in Blu-ray Players
- OPPO BDP-105 vs Sony XA7ES for 2 channel audio question Last post on 4/11/13 at 4:51am in Blu-ray Players
- Are 4,5,6 year & older BD players still receiving firmware updates? Last post on 2/24/13 at 12:41pm in Blu-ray Players
Related Reviews
Official OPPO BDP-103/BDP-105 Anticipation Thread - Page 70
Gear mentioned in this thread:
- rdgrimes
- Trader Feedback: 0
- Oppo Beta Group
- offline
- 14,807 Posts. Joined 3/2004
- Select All Posts By This User
I have an older DVD player that outputs SPDIF at 192KHz (there's no dearth of these around). Still, this issue is no
huge concern for me, as my prepro can handle it just fine. My comment was general. I view this as an unnecessary
disadvantage, notwithstanding the other 192KHz capable input options. I've done a fair amount of product definition
and market positioning in my life and I guess the habit sticks :-).
-- Ron
The question still remains: what source material can you play on that "older DVD player" that is 24/192? And if that source material exists, can't it also be played on the Oppo?
can't wait to get the 105, are there any news when they will start shipping? Hopefully it comes to Europe at the same time as in the US:
I would like to use the 105 as a pre-amp, is this a reasonable approach? Since the pre-amp of the AVR is by-passed, the sound quality could be improved?
Or would a high end pre-amp between the AVR power section and the Oppo be better than feeding the Oppo analog outs directly into the power amp?
If a high end pre amp would be better, then:
Does a High end Pre-amp "improve" or does the Oppo "worsen" the analog signal before it is fed into the power amp.
Since I never had a high end pre-amp/power-amp combo, I was always curious what a good pre amp really is doing, since the volume can be modified with a variable analog out of the Oppo,
Regards
Thorix
First off, Bob thank you for the very thorough responses.
On #3, the DLNA server definitely seems to be the way to go in my apartment. It saves me from buying another device (Mac Mini) and as long as my wireless network does not have issues, the files are played at their original hi-res formats, if applicable.
So now one new question for the group. Given the importance of audio quality in my system, what is a better option: BDP-105 or BDP-103 plus a good DAC like the MyTek Stereo 192-DSD-DAC.
The BDP-105 option uses passive cooling. The BDP-103 / MyTek option obviously costs more and requires additional interconnects but ignoring cost, may provide a better DAC if I used a coax connection between the Oppo and the MyTek and a better headphone amp.
I know the BDP-105 isn't out yet so this is all speculation but from the 93/95 user base, did many opt to go with the 93 as a very good transport and buy an external DAC?
Is there anything else I am missing in terms of comparing the current alternatives above?
You could also try a Eastern Electric Minimax Dac Plus if you like the sabre chip. It's around the same price as the Mytek and for reasons unknown sounds quite a bit better than the BDP-95 in my opinion. If you upgrade the opamps the gap widens further to a level that I thought near impossible for the price. I think it really depends on how much you want to spend and how much two channel listening you do.
Having said that, the BDP - 95 is no slouch at all and beat many so called highly rated dacs. It can also do many other things a 2 channel dac cannot do.
I think it also depends on the system you have as well. For example I have two systems, one a highly resolving 4 way active horn system and another more "normal" system. The sonic differences between dacs are much more noticeable on the 4 way active system.
Bear in mind Oppo has a 30 day return policy so you could try the BDP 105 and if you don't like the 2 channel sound return it and go the BDP 103 route and buy an external dac
Edited by djkiwi - 11/4/12 at 11:26am
- jimshowalter
- A/V Enthusiast
- offline
- 301 Posts. Joined 11/2005
Totally agree with the Blue Jeans cable recommendation. I use them for everything in our system (google for martin logan system 420). They are inexpensive, very well made, and attractive. Plus the company is a joy to work with.
My strong recommendation is that you do not spend any money upgrading the power cable beyond what OPPO includes with the player. The reason is simple: There is no logical explanation why the last 3 feet of power cord should make any difference whatsoever when placed at the end of the several hundred feet of contractor's power wiring in your walls and the several miles of utility wiring and industrial transformers between you and the power plant.
--Bob
Again agree, but if one feels they simply must "upgrade", the Neotech cords from Take Five Audio in Canada are a comparative bargain. You can see examples in the photos of our system.
I have no financial or other interest in either company, just a happy consumer.
- Bob Pariseau
- Read the FAQ!
- online
- 24,272 Posts. Joined 7/2004
Will the 105 Multi-task?
Say you want to use the 105 to watch Directv at the same time that you are listening to music through the DAC digital input and/or into the headphone circuit, is the only way to multi-task is to use the TV's audio for Directv, at the same using the 105 split AV HDMI to handle the music, whether it be inputted from an external CD player or computer through the DAC or from the 105 universal player itself? Could you please lay out the options that can be done at the same time?
Thanks for the clarification.
When the player is set to use either HDMI input, then the only audio/video it sees is what is coming in on that HDMI input. When set to use a Digital Audio Input (the USB DAC or the Optical/Coax inputs all found only on the 105), then the only audio it sees is the audio coming in on the selected input, and it sees no video input from anywhere.
When the player is set to operate as normal -- i.e., when Blu-ray Player is selected as "input" -- then the player does not see anything coming in on the HDMI Inputs (103/105) or the Digital Audio Inputs (105 only) inputs.
The only "multi-tasking" you can do is what is inherent in the media file playback portion of the Blu-ray Player. For example, you can set music playing from a media file and then also view a slide show of photo media files.
--Bob
- Neuromancer
- offline
- 10,430 Posts. Joined 7/2005
I guess Oppo will come again with an correction for this answer... This statement here is fully wrong. The read capabilities of the eSATA port are substantial better than USB one. Faster and and lower jitter (less corrections on the way...) than USB. No interface/speed conversion SATA - USB needed. eSATA is hot swap also... This is actually the meaning of an eSATA port - hot swap!
So yes, eSATA is faster on a computer, but not a Blu-ray player like the BDP-9x series of players.
AC coupling? Yes all our players are/were AC coupled... Wait a minute.. NO!
Edited by Neuromancer - 11/4/12 at 8:59pm
- dmusoke
- offline
- 2,033 Posts. Joined 7/2009
Well said Neuromancer ...obviously the 105 has been a beta product for a while and design changes are expected as part of its maturing process. It also seems that the headphone amplifier was a late addition to the feature set, of which i am very glad. Had a screaming female neighbor recently yelling at me on a friday night(9pm) to turn down my music in my small 750sq.ft 1-bedroom apartment room. I guess having dual 1000W subs as part of a 5.2 audio system doesn't help either(I was having fun anyways
Headphones will help me get along with my neighbors a little better. Since headphones are a new world to me, this is yet another purchase i'll have to deal with soon. I hear magneplanar and electrostatic types sound the best overall?
Do they sound better overall? It's a matter of taste.
I've been using the Sennheiser HD 650. I'm quite pleased with the sound.
- Neuromancer
- offline
On the Blu-ray players eSATA was not bus powered, did not support hot swapping, and its bus performance was restricted by the same bus used for the USB interfaces. For this reason there was no performance benefit, and in many cases, the performance was actually lower using eSATA than USB.
They said all of the players except the BDP-83SE stereo output was AC coupled. This was incorrect for the BDP-95 and was corrected very quickly by OPPO support.
Again, they covered why this information was incorrect when previously discussed. The engineering group had made changes to the final production model which removes the 2 channel ground and instead uses these channels for the headphone amplifier. The BDP-105 is still technically not released, so some changes have not been passed down to the front end channels.
Sorry, bat your explanations about SATA interface er either wrong or misleading.
eSATA (external SATA) is an interface which support hot swapping and is rated much higher for data transfer. eSATAp is the interface which support hot swapping too, and have power on it.
You can read this here: http://en.wikipedia.org/wiki/Serial_ATA
" both SATA and eSATA support hot-swapping by design. However, this feature requires proper support at the host, device (drive), and operating-system levels. In general, all SATA devices (drives) support hot-swapping (due to the requirements on the device-side), also most SATA host adapters support this command."
When an interface is named SATA then it have to have specifications as SATA and not as USB. I will do a research about the buses of the Oppo processor (if I will find infos on it) , but I seriously doubt that they who created/designed that processor used the same bus for both SATA and USB interfaces. This is a mess which no any chip producer will accept it... Else such compromise will be specified very clear in the chip datasheet or documentation.
About the corrections from Oppo on those mentioned statements in that my post, it was not necessary further comments and explanations. The explanations were also out earlier than your answer/post. I just pointed out as it were come out (corrected) from Oppo himself...
Edited by Coris - 11/4/12 at 11:50pm
- Neuromancer
- offline
- dmusoke
- offline
I hear electrostats have the best midrange/treble but are weak in bass. The other types might have have the midrange/treble magic of the electrostats but have much stronger bass.
Probably true IF the efficiency is too low which is typical of some or most electrostatic headphones. The Hifiman HE-6 is rated at about 83dB/mW efficiency which is low hence requires an amp.
Wow, highly efficient at 91dB/mW and many superb top notch reviews. How do you like their deep bass response? Is it abundant or merely satisfactory? The $1K price gives me some pause though, but as they are planar magnetics with superb frequency response, the price should be warranted. Something new to drool after
Edited by dmusoke - 11/5/12 at 2:09am
Please look at my response carefully. I framed my responses explicitly around the hardware implementation of the BDP-9x series f players, and not around the capabilities of eSATA technology. The BDP-9x series of players did not support the full functionality of eSATA, which includes (but not limited to) hot swapping, bus powering, and increased bus speeds. These were all limitations of the interface used in the BDP-9x series of players, not eSATA technology.
OK! Get it...
- JonStatt
- offline
- 1,890 Posts. Joined 8/2001
I am sure they will work with the BDP-105, but I suspect they are compressing the dynamics. Here is what Audeze have to say about choosing an amplifier on their own website.
So, an amplifier that can output 1w is the bare minimum. Amplifiers will have distortion metrics at different wattage levels. If an amp can output maximum 1w it would be barely sufficient and might have a lot of distortion at full output.
The Oppo is only delivering barely a 10th of the minimum that Audeze recommend at the operating impedence. Even if Oppo have been "tight" with their specifications and its nearer double that, its still far away from providing the dynamic range that these headphones have.
Just on a side note, we are talking about magnetic planar headphones which have become increasingly popular in recent years as audiophile solutions. However I suspect the limited power output will have a similar impact on other more demanding headphones as well (normal speaker cone).
Electostatics are different again and require a completely different system to drive them. Right now the only major player in this field producing units is Stax and those headphones typically are bought with a companion amplifier of their own to drive them.
Edited by JonStatt - 11/5/12 at 5:01am
- dmusoke
- offline
Jon:
The LCD2 is rated at 60ohms of which Oppo outputs a stated 91mW continous into that impedance. With an stated LCD2 efficiency of 91dB/mW, it means the maximum the Oppo would produce into the LCD2 is [91mW + 10* log(91mW/1mW)] = 110.6dB which is plenty loud enough. and this isn't peak power but continuos power. The number is higher depending onthe headroom Oppo allows is TPA6120 headphone amplifier to have. This agrees well with Oppo's assertion to me that they've tested many headphone types and have yet to find those that cannot be driven to satisfactory levels.
Have you tried to listen to 110dB spl with normal speakers? If not, you will not do so for long to protect your hearing, let alone incur the wrath of your family and/or neighbors. This is simply way too loud and infact dangerous to your hearing mechanism for any prolonged amount of time.
I found this snippet on the net...
How loud is too loud?
Experts agree that continued exposure to noise above 85 dBA will cause hearing loss. To know if a sound is loud enough to damage your ears, it is important to know both the loudness level (dBA) and the length of exposure to the sound. In general, the louder the noise, the less time required before hearing loss will occur. According to the National Institute for Occupational Safety and Health (1998), the maximum exposure time at 85 dBA is 8 hours. At 100 dBA, the maximum exposure time is one minute and 29 seconds.
The following are decibel levels of common noise sources around us. These are typical levels – actual noise levels may vary depending on the particular item. Remember, noise levels above 85 dBA will harm hearing over time, anything above 140 dBA can cause damage to hearing after just one exposure.
Edited by dmusoke - 11/5/12 at 9:56am
I`ve generated an 80Khz digital sound file. I`ve used Audition - Tone generator which (on my computer) it gave me the opportunity to generate a "sound" whit such frequency. At last it worked and I had an sinus signal 80Khz on that (mono) file. This were stated by the software itself, and I had to trust it. I put it that file on a USB stick and set it in into BDP 95 port. Played that file as usual WAV file. I was very surprised to see on the RCA output, on oscilloscope, that 80 Khz sinus signal... Not any distortion, just fine sinus measured 80Khz! The level it were approx. 60% of normal audio signal...
I still think that is quite amazing that the whole digital and analogue hardware (even the software) inside the player could pass such test.
More about this test is to be seen here: http://www.diyaudio.com/forums/digital-line-level/196474-ess9018-try-new-try-more-14.html
LCD-2's are not electrostatic headphones and the oppo cannot play electrostatic headphones.
- JonStatt
- offline
Jon:
Yes I hope you are right. I was simply quoting what Audeze suggest on their own website. I have to admit I was thinking if I would be listening continuously at 90dB with odd peaks up to 120dB. However the hearing damage concerns are dependent on continuous stimulus and not milli-second peaks. When I use my home cinema, it is normally set such that it peaks around 100dB at moments of "dramatic circumstance", but typically is somewhere around 75dB. I am actually also trying to understand the maths here, because Audeze are asserting to produce 120dB would require 1000 times the power to produce 90dB, hence the need for 1W. But you are suggesting 110.6dB from 91mW. On the face of it what you describe is more than sufficient and that Audeze themselves are misdirecting what you really need, which could hamper sales of their own headphones!
LCD-2's are Planer not electrostatic. Stax are Electrostatic and require a specific amp type....I would expect the 105 to work fine with Ortho or Planer HP's. BTW, I'll drop in another vote for the Sennheiser HD650's!
- dmusoke
- offline
Any views on performance / ability of the Oppo headphone amp to drive the Beyerdynamic headphones such as their new T90: http://north-america.beyerdynamic.com/shop/hah/headphones-and-headsets/at-home/music-pleasure/t-90.html or the HiFiMAN HE-500 http://hifiman.us/Products/?pid=102 ?
Brian:
For the HE-500, maximum continuous power from the Oppo would be 89dB + 10*log(137mW/1mW) = 110.4dB! actually more since the 137mW power rating from the Oppo is spec'd into 32 ohms and it doesn't include the dynamic headroom of the headphone amplifier. The 89db is the manufacturer's listed spec for sensitivity at 1mW into 38 ohms impedance.
The Beyerdynamic T90 is very efficient at 102dB for 1mW input into its 250 ohm impedance. So the maximum continuous spl from the Oppo would be approx 102 + 10*log(23m!/1mW) = 115.6dB or more! The 23mW power spec i've listed in the equation is for a 300 ohm load(as Oppo doesn't power spec a 250ohm load).
Either headphones should be plenty loud and dynamic enough as the Oppo can produce greater than 110dB continuous power outputs from them, assuming they can handle these spls w/o breaking up or distorting. If you account for the amplifier's dynamic headroom, the peak levels would even be greater.
Edited by dmusoke - 11/5/12 at 10:49am
- dmusoke
- offline
- Neuromancer
- offline
- dmusoke
- offline
As Neuromancer has indicated, his Audeze LCD2 are driven to satisfactory levels by the 105...
- Neuromancer
- offline
Wow, highly efficient at 91dB/mW and many superb top notch reviews. How do you like their deep bass response? Is it abundant or merely satisfactory? The $1K price gives me some pause though, but as they are planar magnetics with superb frequency response, the price should be warranted. Something new to drool after:p ...
I would not personally purchase the Audeze LCD-2 if given the choice. I use the Grado RS2i for my primary headphones, and I prefer them over the Audeze LCD-2. Although the Grados are very bass anemic, you get to feel the bass, something that you do not get with planar which are designed around hearing, not feeling. The Audeze LCD-2 do slope off at the mid-high to highs, whereas the Grados actually gain amplitude at the same frequencies. For me I end up preferring the more open, warmer audio that I get from the Grados versus the more clinical Audeze LCD-2. Or I just do not want to spend another $1000 on headphones, so I am going in biased.
Another thing to consider is that I do not own the Audeze LCD-2 and have not been able to play with them for extended period of time. When listening to the Aduze LCD-2 I have been making pilgrimages to OPPO's corporate office, so I have only spent an hour or two per visit listening to the the headphones. It is very possible that given more time with the headphones, particularly after messing around with external amplification versus the built in headphone amplifier, may produce different results and experiences.
Edited by Neuromancer - 11/5/12 at 11:19am
- Neuromancer
- offline
- Official OPPO BDP-103/BDP-105 Anticipation Thread
Recent Discussions
- › Energy Owners Thread 15 seconds ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 47 seconds ago
- › In-Ceiling Speakers for Music and Movies 48 seconds ago
- › Klipsch RW-12d on sale for $299 at Newegg.com again today! 1 minute ago
- › Klipsch RW-12d Subwoofer - Only $299 - Save 70% 2 minutes ago
- › TD15M - SEOS12 - BMS4550 / theater progress / Dual TD6M - SEOS12 -... 2 minutes ago
- › Official Rythmik Audio Subwoofer thread 2 minutes ago
- › Drive-in Theaters get a Digital Facelift 2 minutes ago
- › Will you head back to the consoles, or double down on PC gaming ? ... 3 minutes ago
- › Official Sharp AQUOS LC-80LE844U Owners thread 3 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
