Sometimes people are looking for rackmount HTPC cases and I thought these were pretty cool, especially if there is any choice in wood color besides the blonde wood. There are two sizes, mini-ITX and micro-ATX. The ears can be removed and they can be used as regular desktop cases as well. Here are the specs:
D-213-MATX-WB mATX
Standard Drive Bays:
3.5" Drive (internal): 2
5.25" Drives: 1
Expansion Slots: 4 (low profile)
Material of Front Bezel: Wood
Material of Handle: Aluminum
Material of Main Chassis: Zinc-Coated Steel
Front Connector: 2x USB 2.0
Motherboard Size: 9.6 x 9.6 (microATX, mini-ITX)
Optional Fan: 80mm x2
Dimensions (WxHxD):
19.00" x 3.50" x 15.35"
482.6 mm x 88.9 mm x 389.9 mm
D-118V2-ITX-WB mITX
Standard Drive Bays: 2.5" Drive (internal): 2
Expansion Slots: 1
Motherboard Size: 6.7 x 6.7 (mini-ITX)
Optional Fan: 40mm x3
Dimensions (WxHxD):
19.00" x 1.75" x 11.00"
482.6 mm x 44.5 mm x 279.4 mm
Notes
1. 3.5" hdd cannot be placed when expansion slot is used.
2. Standard I/O shield will NOT fit any 1U chassis.
3. Expansion slot requires riser card
They aren't available yet but they are "coming soon".
Edited by StardogChampion - 9/7/12 at 10:00am
