So I'm about to pull the trigger to secure my lot, ink the contract, and plan ground breaking on a 2800sq/ft home (3800 with basement). I will be doing the automation and DV myself when the time comes. Current estimated completion date is Sept 13. So equipment will be bought as late as possible.
I have my automation pretty much wrapped, and now I'm looking at DV. I'm trying to get my actual wiring needs streamlined to what's actually needed, and not just pulling wire for the sake of pulling. Why pull 18 cat6 when 2 is all that's needed?
I plan on having 3 TVs at first. Master bedroom, upstairs living room (kids play/toy room) and main living. After the basement is done it will have 2 more (rec room, and bar, same source is fine as its an open room). I will also have a dedicated theater.
My question is, what system would you use, and what would you pull to each location, here is what I'm thinking.
Hardware:
- HDanywhere multiroom+ 4x4 (or equivalent on this side of pond, all I can find is uk stuff). This seems so easy. Single cat6, 4 sources, 3D/HD/4k, Internet, and IR control pass through.
- 2 bell pvr, 2 ATV (or other that could play lossless BD rips off NAS). ATV is nice for AirPlay of funny clips etc from people's phones etc, but can't do lossless from server, requires re-encode.
My estimated pulls:
- 3 cat6, 1 for HDbaseT, 1 for spare network, 1 spare for phone/fax/future IR etc.
- 2 RG6, this gives me the option of putting a dedicated PVR at location, or RF.
What are your thoughts. Are there better options? Does the HDanywhere receivers combat the 2.1/5.1 audio issue when using a matrix? More cable? Do I jump to 8x8? Or use splitters, if I add addition TVs? I don't see needing more the 4 sources. But maybe just more outputs. 8x8 is steep, I'm trying to keep the costs realistic.
I'm just trying to price the wire, and get labour quote to install it, should my work keep me far to busy.
Thanks for your time everyone
Sent from my iPad using Tapatalk HD
Hardware:
My estimated pulls:
