AVS › AVS Forum › Display Devices › CRT Projectors › Curved scope screen and nvidia
post #1 of 4
Never thought I would be back in the CRT game but I guess never say never. I have a custom curved screen
I made 133" and is 7" deep curve and want to know with my nvidia graphics card what would be the custom
resolution for a Sony G70. I was thinking constant width and height and just expand widescreen to 16X9
like I did with my RS2 and lens.
Thanks for the advice
post #2 of 4
Use 800x1920 for scope and then you'll have to go smaller width wise for 1080x1920p .
For the 800p the image will look taller and go off the top and bottom of the screen so you'll have to re size the hight in the PJ settings from what it would have been for 1080p
here read this post
http://www.avsforum.com/t/737385/want-to-optimize-your-scaler-and-crt-calculations
Athanasios
post #3 of 4
Thanks for the link.
post #4 of 4
Ended up going with 1280X544p 96hz and the picture just exploded off my curved screen thanks :cool:Athanasios:cool:
for a good read and fix to my 128" scope screen. 1920X800 was to soft but looked good.
  Back to Forum: CRT Projectors
