Updated 5/11/13:
Now that I've finally gotten most of this room roughed out, I figured it was time to post some pictures and some basic info. As my wife can attest, this room is a constatnly evolving projecting - the setup is subject to change at any given day, haha. This is the 3rd listening/media room in my house and the most recent. There are 5 total rooms in my house with audio/video setups in the house ranging from the garage to this room, but this is my favorite so far. I'll post up some info on the other rooms sometime soon.
The room before - light yellow paint, shelving in the corners, Mitsu 65" DLP, basic Polk Monitor 70 setup, HK receiver, etc.
Setup as of today:
A few months ago the wife and I decided we wanted to change to a projector. At first, this was going to be a simple ceiling mounted install that would be a directly replacement for the DLP you see above. The project evolved into removing the shelves, restructuring the corner frame/drywall, paint (entire basement!), new dedicated 20A lines for the equipment, remote triggered relays, moving furniture, new decorations, etc. I'm sure MANY of you can relate!
Notes: While I'd like to do something with the ceiling, converting to black is likely not practical since this is a multi purpose room.
Viewing area: (open) 13x22
Bar area: 19x22
Hallway: 5x20
2 other rooms are in the basement comprised of a a gym/play area and a workroom
Electronics:
Receiver - Denon 4311ci
Media - Sony PS3, Xbox 360, Verizon FIOS HD DVR
Power - Panamax 4400 20A Conditioner/Surge protection X 2
Projector - Epson 8700UB
Screen (updated 5/1/2013) - DIY AT screen using Seymour XD fabric, 130" in 16:9
Sub Amp - Sanyway FP14000, LG clone. Backup amp: Crown XLS5000, driven by remote triggered relay in utility room.
Mains amp: Crown XLS2000
EQ - MiniDSP, balanced. Currently used for a small +3db LT
Speakers:
Mains - Now DIYSoundGroup B&C Sentinels
Center - Now DIYSoundGroup B&C Sentinels)
Side Surrounds - DIY SEOS based Gorilla design using 10" Selenium woofs and Denovo DNA350 CD
Rear surrounds - Currently Klipsch RS-35's
Subwoofers - 4 x Dual opposed Dayton 18" HO's, sealed cabinet each 7 cubic feet
Room Treatments - DIY
All treatments 4" thick 3# rigid fiberboard with 1x4 frame and covered with black speaker cloth. Most are 2x4' in size.
4 X front corner bass traps (nearly floor to ceiling)
3 X rear corner bass traps (floor to ceiling)
4 X side wall traps
Ceiling - 1 foot thick R38 above tiles over entire ceiling
Coming up - front wall treatments behind new AT screen
Other:
Plateau Equipment rack
Omnimount Projector Mount
Wood Technologies Center Channel Stand
Dayton Omnimic V2
Euroboom Mic Stand - for room sweeps
Logitech Harmony 880 Remote
Monoprice IR Extender
Monoprice 12gauge oxygen free speaker cable (all)
Monoprice Coaxial cables
Monoprice Wall plates, assorted
Gym area
Hafler DH-200 Power amp and matching pre-amp
Bose 301 speakers
Energy 10" Subwoofer
Pictures
Corner 'shelves' removed and bases cut down and reframed:
Wall sealed and primered
Room after paint - Sherwin williams Flat black and Harbor Grey Sides
Corner area made into custom speaker stands, flat black
Screen assembly
Projector hung, near flush mount
Custom wallplate behind rack
Screen hung on the wall
Main view of the room
Bar area leading into theater
Screen
Equipment rack
Back hallway
Gym area
Edited by Gorilla83 - 5/12/13 at 4:11pm
Setup as of today:
Bar area: 19x22
Hallway: 5x20
Electronics:
Speakers:
4 X side wall traps
Other:
Dayton Omnimic V2
Gym area
Bose 301 speakers
Pictures
Screen assembly
Screen
Equipment rack
Back hallway
Gym area
. Having the GTG there should be a fun time.
moment when they were all in place.
