AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon AVR-1910 & LG BD-640 - Audio Problem
post #1 of 2
While running BluRay movies on LG BD640 and selecting HDI Passthrough as an option, I do see the blue light on Denon come on - yet the output sound is so weak that it hardly makes out.
Only, if I let BD player decode the sound, that it works. Btw, this problem does not exist with regular DVDs at all
Has anyone seen this issue, and come up with any resolution? A firmware update to any of the equipments, may be? (It has to be fixed at Denon's end since my BD player is region free - and I cannot afford to loose that feature)
post #2 of 2
Yes, this is a known issue with the XX10 models with some LG players. Check for a Denon authorized repair facility in your local area that can install the firmware update that resolves the issue.
