AVS › AVS Forum › Video Components › Home Theater Computers › why is internet tv going to be removed from wmc?
post #1 of 8
i used internet tv to watch hd nation and it said internet tv will be removed from wmc on 9-20
post #2 of 8
I hope it is not going to happen. I use it quite a bit, too.
Where did you see this?
post #3 of 8
when i start internet tv i get this message
on septtember 20, 2012 the internet tv experience in windows media center will longer be availble.
post #4 of 8
I have no idea why it is being removed but Revision3 has a plugin that you can watch HD Nation on. It worked pretty well when I used to use wmc.
http://revision3.com/leanback_windows
post #5 of 8
Gee, you don't suppose it has anything to do with MONEY do you?
post #6 of 8
Probably because no one uses it so they dont want to support it anymore.
post #7 of 8
I was wondering what happened when I saw it missing from the TV strip.
post #8 of 8
While they're at it, why don't they get rid of the "Learn More" website button that no longer works.
