Hi,
I have a D3 (i1 Display Pro) here which I will profile to the i1 Pro (Rev D) I just purchased.
It appears that this spectro / colorimeter combo is a good consumer level solution, I wonder would the Discus / i1 Pro combo give me better results ? I'm assuming the only improvement would be the better repeatability accuracy of the Discus over the D3... Anything else that the Discus brings to the table as an improvement to the D3 in a combo solution ?
Regarding the profiling process and workflow:
1) For my previous calibrations (using just the D3) I have placed the D3 directly on the screen - do I place it directly on the screen for the profiling process as well ?
2) what is the placement of the i1 Pro when profiling ? on screen ? on a tri-pod a few inches away ?
3) use the (profiled) colorimeter for grayscale & gamma and the spectro for gamut work ?
Thanks for any help, input and general info on this process.
- M
- M
