Originally Posted by Krutsch
I have a VSX-1122-K w/ the BDP-62FD. I set the Sound Retriever function to 'On' all of the time. When you are playing back Blu-rays, it disables the function - it uses Sound Retriever Link from the player to feed the bitrate to the AVR and higher bitrate (lossless audio) will disable the SR playback function. With DVDs - especially one's with DD 5.1 audio, which is very compressed, it will auto-magically re-enable playback to 'enhance' the sound. It sounds like you like the effect and I do to; with standard definition movies it really enlivens the audio.
With MP3/AAC (compressed) audio, it works much the same; I have a lot of FLAC (losssless CD audio) and it seems to disable it there, as well.
When I play CDs, SACDs and DVD-A discs, I always set the AVR to Pure Direct mode, which disable all processing - including SR. I think you will find, however, for CDs you won't need/want SR, but If you are playing CDs, and you like the SR processing, then make sure you have set the AVR to 'Standard Stereo' or one of the surround modes - not direct.
Let us know if you still can't get this to work as you expect.
lol..well said mr krutsch.... how are you by the way... ohh i was wonding do you have a record player ? ..am thinking of going back to some vinyl ..
. For me have never had any issues with playing back movies on blu ray fist time I have ran into these issue's.
