AVS › AVS Forum › Audio › Soundbars › Who is using a Soundbar with a Projector setup?
post #1 of 10
Thinking of going with a sound bar vs a traditional 5.1 setup to be used with my projector.
Im hoping someone else is doing this now and can tell if if they love, like or hate it. What brand you are using, what brand do you think is the best. Its my media room so on this part i will have a budget of about $450. As it stands im thinking about the Yamaha YHT-S400BL but that was found on my first search. I am open to other suggestions.
My room is square 11.5' x 22' but I will be sitting about 8 or 9 feet max back from the screen. I envison the sound bar to be under my screen right at ear level.
post #2 of 10
I have used soundbars with my projectors and they have worked great,,, just get a bar that has HDMI inputs and you will be fine,,,, I always used the Sony CT soundbars.
Cheers
Davyo
post #3 of 10
I don't use one with my projector, but why do you want to? I would rather use a pair of bookshelf speakers than a soundbar.
post #4 of 10
Cheers
Davyo
Thanks Davyo. I will be using a Sony soundbar for the first time. I hope a wireless subwoofer will be nice still being wireless I can move it quickly smile.gif
See my sig Jim. I flooded. Since it(the flood) has never happend before and might happen again. I want a way to remove items out of my room quickly.The room is mostly made of glass so limted mounting options. Sound bar I can mount with no issues.
I lost all my bookshelf speakers and subwoofer. This is my attempt to make it easy to save items or I would go back to my 5.1 setup.
Edited by Wytchone - 9/14/12 at 5:26am
post #5 of 10
HERE is a link to my sound-bar/projector setup. This setup would fit your budget if you just got the sound-bar and a receiver and left out the sub woofer. Without a sub-woofer this bar will still be bassier than the plastic sound-bars with sub-woofers that are most recommended here. You can add a sub at your leisure if you see fit.
post #6 of 10
The more I read about this the more I like. Wish is was HDMI for ease of movement. Still I can get it up higher then say foot of the gound easy.
I think you may have sold me on this. I did save my 7.1 receiver so I can get the base for this also.
Edited by Wytchone - 9/22/12 at 9:51am
post #7 of 10
Cheers
Davyo
I think I'd invest in some basement waterproofing if you're afraid of it happening again.
post #8 of 10
Best I can do is do lay tile. Issue is till we get the Corp of Enginners report, we have no idea if it will happen again. It just has never happend before.
Edited by Wytchone - 9/22/12 at 7:30am
post #9 of 10
I have a YSP 5100 with a velodyne cht-10 and Epson 1080UB/100" electric. Very happy with it, I've upgraded from ysp3000 and ysp1100 and they were also excellent. Pls don't listen to that advise of using bookshelf, that makes no sense unless you have at least 5 but it's not worth the hassle. Yamaha sound bars are awesome, I don't know how they do it but every single person who has been to my home tell me they can't believe the sound is coming from 1 speaker. And don't worry about output, it can play very loud and clean. I've had very good 5.1 systems with a denon 3805 with mid level and high level Kef speakers and Hsu subs VTF 2.3 and ULS 15 and what I have now is no compromise to what I've in the past NO sir ree.
The 5100 is very long so it I had to put it on top of my Kathy Ireland ent center which has 31" opening with a cover that can house most sound bars so I used that when I had the 1100 and 3000 and people could not see the speaker so they were like where is the sound coming from. Oh, and my room is 23x13x8 with openings to a kitchen and dining room to the left that you can't see.
post #10 of 10
Thanks Zoey! You are one of the few people who have said what amazing sound you can get out of a bar. Of course the one you list is pricey but it does give me hope smile.gif
  Back to Forum: Soundbars
