AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Question on Upgrade
Question on Upgrade
post #1 of 6
I now have a Pioneer VSX-23THXH and want to upgrade a receiver that uses 3D. Can you guys recommend me a receiver equal to this one. I don't want to spend A ton of money. Thanks
post #2 of 6
If you're satisified with the audio from the AVR, you may simply want to consider upgrading to a dual HDMI 3D Blu Ray player instead so you can pass the 3D video to the TV directly and the HD audio to the AVR separately.
post #3 of 6
I love this receiver. Could you recommended me a 3d bluray player. That has 2 hdmi. Now for the video one hdmi will go out from the player to the tv. And the other hdmi for the player go to the receiver. Is that right.
post #4 of 6
post #5 of 6
This one seems nice. Lot cheaper that a new receiver. Sony BDP-S790.
post #6 of 6
Yup. And the 790 is also WiFi capable with smart apps so you can control it using a smart phone app.
