What are the best settings you guys have found for movies, tv and music. Trying to get my SSA immersion level just right for watching tv and I'm having a hard time deciding what sounds best.
10 for Movies
0 for Music
Music is a tuff one since the higher number takes the vocals out of the mix a bit.
For movies ya really want the effect so just keep,it on 10.
Just my thoughts
10 for Movies
0 for Music
Just my thoughts
So just the stock settings. Have you found a sweet spot for tv yet?
Yes, overall no.
I feel 10 for movies felt the best.
It's so easy to mess around with the sound, you might find something works better for your ears, but I like 10 for movies, for music I'll move it around a bit and see what setting fits best for the program, but 0 seems to feel good to me
Yes, overall no.
Yeah I like the adjustments that can be made as far as center, sub and surround effect. It's just that I find myself constantly tweaking them. Have you messed with the DTS settings yet?
how are you liking your solocinema xtr sound bars, I have one on the way should have it by Friday, she is going under my sharp 70" can't wait... any advice on set up?
What is the newest firmware on this unit? Nice unit sounds good, what should my play station 3 sound settings be at? I get a thumping sound from the sub woofer when i foward fast or pause, its switching from pcm to dolby digital when i do this? Doesnt do this with my cable bix...
