AVS › AVS Forum › Display Devices › CRT Projectors › WTP Sony G70 blue tube!
post #1 of 5
If you have one please send me a pm.
post #2 of 5
You might want to check with VDC as they rebuild CRT projection tubes. Here is their web site:
http://www.videodisplayprojection.com/html/vdc_catalog.html
post #3 of 5
If your wanting G70 Tubes I would contact Greg Eisemann of Eismann Theatre..
Greg Has the Highst Spec G70 Tubes ever manafactured, Boeing Simulation Grade HR tubes (Bare)
http://www.eisemann-theater.com/
Here's a Review I did of the first set of Eisemann Sim Grade HR tubes installed in A G70:
http://www.avsforum.com/t/1286517/new-simulation-grade-hr-tubes-for-g70s
post #4 of 5
Thanks will do. I forgot about Greg and VDC
post #5 of 5
Thanks to a forum member I scored a blue tube and should have it installed over the weekend!
  Back to Forum: CRT Projectors
