AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic TC-P55GT30 DLNA server connection failed
post #1 of 2
This is the situation. I'm trying to play movies and music from computer to Panasonic tv using the DLNA feature. On my screen I shows my computer server click on it and says server connection to server failed. I have tablet and smart phone and can play things off it just fine. But it would be so much nicer to use my computer instead of more products. Any info would be greatly appreciated.
post #2 of 2
Not sure if you did this but once you have the tv's DLNA client up and running then go into your PC's network properties and allow it. Win 7 (higher level versions) have native DLNA support so that should work. Other operating systems and MAC's need an additional DLNA server program.
