Got the two new fans installed while on lunch today. Wasn't expecting them to show up this early! Saves me from having to do it after work when I'm all bleh.
Before
After
Set up Prime95 and let it go for about 20-30 minutes (btw, I had just stopped the test when I took the picture)
I was usually seeing mid 60's during these tests. Maybe if I let it go for longer it would reach there, I don't know. Seems like the new fans work well and no annoying blue LED!!
Fan noise seems about the same but there is now an extra fan so...no biggie.
Improved cable management is next on the list of things to do. The CPU cable is just a couple inches short of being able to be hidden behind the mobo. I'll need an extension, for sure.
Before
After
Fan noise seems about the same but there is now an extra fan so...no biggie.Improved cable management is next on the list of things to do. The CPU cable is just a couple inches short of being able to be hidden behind the mobo. I'll need an extension, for sure.
Compact Flash is an IDE standard interface. I had a fast 16GB CF card hooked up to my old board's sole IDE port to host my swap file. You'd be amazed at how fast platters are when they don't have to worry about jumping back and forth to a swap file while trying to load something.
