AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › SIM2 CINEMAQUATTRO 4K DLP Projector
post #1 of 4
SIM2 had their new CINEMAQUATTRO 4K 3D DLP behemoth on static display at CEDIA. It's a Christie with SIM2 processing, color, and triple-flash 3D. I guess if you have the disposable income and are in the market for a big state-of-the-art commercial size theater conveniently located to where you eat and sleep, this would now have to be added to the short list of projector possibilities. Of course you would need a projection room and chimney prepared for it prior to installation.
post #2 of 4
$158k.
http://www.engadget.com/2012/09/08/sim2-158k-cinemaquattro-4k-dlp-projector/
post #3 of 4
Originally Posted by Solfan View Post
$158k.
I'll take two.:l:
That should make a fine passive 3D set up. Will you be putting that on the Amex Black card?
post #4 of 4
Interesting that [it seems] the replacement lamp looks to be about the same $$ as the early JVC G10 series.
Edited by Solfan - 10/9/12 at 5:24pm
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
