AVS › AVS Forum › Audio › Receivers, Amps, and Processors › parasound hca-800II amp , help needed !
post #1 of 2
I have recently bought two used parasound HCA-800II amps. And the problem I have is that one amp turns on The small red led glows but does not switch to green. it stays in standby mode. After about maybe 2 min of being on it does start working . The amp sounds great like the other amp that seems to be working correctly. So does anyone have any idea whats going on ?
The other amp after about 5 sec of turning on I hear a click and the red led turns to green and starts to works.
Edited by curtiswhite - 9/12/12 at 5:53pm
post #2 of 2
The unit needs to be serviced, call Parasound to see who they recommend.
Parasound Products, Inc.
2250 McKinnon Avenue
San Francisco, CA 94124
(415) 397-7100
(415) 397-0144 (Fax)
Or live with the delay until it completely stops working and then call.
