AVS › AVS Forum › Other Areas of Interest › Camcorders › The Official: Sony PJ710 / PJ760 / PJ780 / PJ790 Owners Thread
The Official: Sony PJ710 / PJ760 / PJ780 / PJ790 Owners Thread - Page 3
post #61 of 73
Jack,
Welcome to the forums.
Simple way- tap the lcd screen.
Look at the lower right hand side you should see " iAuto " pop up.
Select that and it should turn green. (You can go into settings later and fine tune things to your liking manually. But I find the iAuto does almost everything perfectly for me, so I leave it on.)
Now test the macro setting by moving your camcorder close to an object. You should see a Green Flower symbol that indicates the camcorder has automatically switched over to Macro mode.
You record video and move the camcorder closer towards an object. You can now also switch over to Camera still pic mode (button to the left of the battery,) and use that to take still Macro shots.
Rob
post #62 of 73
Rob,
Thank you for the answer and the help. It was really simple with your method. I previously did a mistake by choosing the Macro mode first, and then trying to get very short focus distance. Now it works perfectly.
Jack
post #63 of 73
Hi there, just opened a PJ790 that was left under my tree, and before I get too far down the road, wanted to ask a quick question: when closed, the LCD screen seems loose/flimsy. It flexes up and down quite a bi ccompared to my previous camera. It does seem solid when open. Anyone else experience this, or should I just package it back up and try for another camera? Thanks in advance.
post #64 of 73
I noticed this on all the camcorders/cameras I have owned: LCD can be pushed up and down when closed, but solid when open.
I think it's a necessity of the design, I would say it's normal.
post #65 of 73
Hi,
I think it's normal in this model. I've got PJ780 and I had similar feelings at the beginning (previously I used some Panasonic camcorders).
post #66 of 73
Thanks for the feedback. On to making pictures!
post #67 of 73
... when closed, the LCD screen seems loose/flimsy. It flexes up and down quite a bi ccompared to my previous camera.
The projectior is part of the LCD screen, making the flip-out bulky. In addition, the flip-out screen can twist/turn and fold back. In addition, it's a weight issue. Sony wanted lighter. The end result is a bulky but light fold-out screen.
In my hand, I prefer the SR-11 to the PJ-790 and wish Sony engineers had studied their target market better,
post #68 of 73
when sony introduced the 1" fdr-ax100 4k camcorder. first thing I look is if it has balanced optical steadyshot. too bad it didn't.
I will wait for sony to introduce the 1" 4k with balanced optical steadyshot. I love my new cx760 with bos system. sony sr-11 does
not have bos system just the super steady shot image stabilizer.
post #69 of 73
It would have to be a much larger camera to use balanced optical steadyshot with a 4K camcorder using a 1" sensor and 12x optical lens.
post #70 of 73
I had bought a PJ710 to take home videos for real estate. Can anyone recommend me the best extra wide lens I can get for it.
It doesn't seem to capture the full width the quality of video is pretty nice.
Thank you,
Jas
post #71 of 73
I believe the camera comes with a step-down adapter allowing add-ons with a 37mm thread to mount on the camera. Sony has a couple of wide-angle adapters still on sale in the market that might be compatible with your camera. There's a catch, however. You have to turn off all image stabilization modes for the camera to work since the whole lens and sensor module of this series of camera models sits on some kind of gyro-stabilization coils and moves independently from the fixed filter thread in front of the camera body (see posted image above). And even if you can live with no stabilization I'm still not sure if the optical design of the camera's lens is fully compatible with those two adapters which first came out over two years ago to fit most Sony Handycam models with a conventional, in-the-lens stabilization system.
My suggestion is since the camera's stabilization system is what sets this Sony Handycam series apart from the rest of other similar camcorders in the market, you'd better stick with the native lens you already have. 26mm should be wide enough.
post #72 of 73
Thanks for your reply P&Struefan.  I probably should drop by a Henry's store and see if they have any adapter in stock.  Is there a better camera you recommend I should review that doesn't cost in the thousands. :)
post #73 of 73
I'm not familiar with other camera brands in this price range as I use mostly Sony gear for my work and vacation. But if you like the new Sony stabilization system like I do it's hard to go back. Even my work cameras costing $5,000-$6,000 don't have anything close to it.
  Back to Forum: Camcorders
