AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Ispell wonky
Ispell wonky
post #1 of 5
So I tyype up a mesage and go to check speling with Ispell. I'm using IE9, windows vistta. My feinds whhen I click change it does something really stannge as you can see. (WIth errors). All I'm doing is clicking the suggested corrections with the change button and it basically mangles the sentence.
Stypeyype umessagesage and go to chspellingling with Ispell. I'm usIE IE9, windVISTAstta.fiendsiwhenhhen I click change it does something reastannicnnge as you can see.
post #2 of 5
You had the same problem in June and apparently fixed it by rebooting...
http://www.avsforum.com/t/1414285/ispell-not-working-correctly/0_60
post #3 of 5
Tried that any it didn't solve the problem. Is there an alternative spell checker?
post #4 of 5
So I type up a message and go to check spelling with Ispell. I'm using IE, windows VISTA. My fiends when I click change it does something really stannic as you can see. (With errors). All I'm doing is clicking the suggested corrections with the change button and it basically mangles the sentence.
Sotypeype upmessageage and go to chespellinging with Ispell. I'm usiIEIE9, windoVISTAtta. fiendsnwhenhen I click change it does something realstannicnge as you can seeWithIth errors). All I'm doing is clicking the suggested corrections with the change button and it basically mangles the sentence.
typeI tyypmessage mesage and go tospellingspeling with Ispell. I'mIEing IE9, wVISTA vistfiends whens whhen I click change it does something stannicstannge as you canWith. (WIth errors). All I'm doing is clicking the suggested corrections with the change button and it basically mangles the sentence.
More details, it will actually work on the first paragraph but then craps out. Here I copied my original test three time and ran the checker.
post #5 of 5
I don't know about IE, but the one built into Firefox works fine.
  Back to Forum: Forum Operations Center
