AVS › AVS Forum › Audio › Speakers › Help Needed - 2 Bookshelf Speakers & a Center Channel
post #1 of 4
I am upgrading some decent bookshelf speakers I've had for years - JM Lab (AKA Focal) Chorus 707. I also had the matching center channel and 10 inch whoofer. The speakers have taken a bit of a beating over the past 10 years through a handful of moves, and I'm not getting to the point of upgrading.
I need some help finding a comparable set, and also some help positioning them on my furniture. At the moment I'm looking at the B&W 685 for bookshelfs + HTM61B for a center channel. I may take keep my old woofer, or I may go without one. Does anyone have suggestions for something similar and or a slight upgrade that I might want to look into? These will mostly be used for TV / Movie watching, and will be light on the music. My overall budget is roughly $2K or under
In addition, I'm looking at where I should place these in my new furniture unit. At the moment based upon how things are positioned, I was thinking I could place the bookshelf speakers on their side all the way on the top of the unit, and the center channel in the middle shelf above the TV.
http://www.potterybarn.com/products/logan-large-media-system-with-bridge/?pkey=e%7Clogan%2Bmedia%7C4%7Cbest%7C0%7Cviewall%7C24%7C%7C1&cm_src=PRODUCTSEARCH||NoFacet-_-NoFacet-_-NoMerchRules-_-
Can someone validate that this won't completely kill the sound, or is the position going to really bother me?
Thanks again for any advice you can give.
post #2 of 4
how about...
this with this
going with sub... or this
the PSB B6 bookshelves should be much better than the B&W. you will even save some dough
post #3 of 4
Food for thought. Thanks for the recommendation... Now to see if I can actually find a place to listen to them.
Also, and feedback on how I can position them? Will it be OK if they are about 3 feed above listening level placed on their sides?
post #4 of 4
Ascend CMT340s pr for 550.00, Center 300, and good ID sub- SVS, HSU, etc...500-600 dollars!
  Back to Forum: Speakers
