Hi All,
Just moved and can no longer use the wired set-up I had to use Netflix streaming on the blue ray player. We do have u-verse and wireless modem in separate building on the property and it's strong enough signal to use laptop next to where tv/blue ray player goes.
So I thinking to try and see if I can stream movies wire less, but need to find a reasonably priced Lan adaptor that works with the 110 player.
Are there any ones out there that are compatible, except strictly Panasonic?
I was thinking trying to find one on e-bay for cheap...
