AVS › AVS Forum › Video Components › Home Theater Computers › Stopping Media Centre
post #1 of 3
Windows 7. How do you stop media centre from loading when you press menu button the Microsoft remote? I have Mediaportal to autostart, so if you press menu whilst navigating mediaportal, mc loads up.
post #2 of 3
Go into MP Configuration, then 'Additional 3rd Party Checks', can't remember what's actually in that screen, but one of them is to implement MPTray, which will disable 'green button' start-up of WMC.
post #3 of 3
I also run both MediaPortal and WMC (for my HDHomeRun Prime). Under Win 7 you can PIN an application to the tray and activate it with the Win-# command. I have my Harmony 300i programed to trigger Win-1, Win-2 from the first 2 of the 5 buttons they have around the INPUT button. This way I start MP with a remote button and all is well... well, maybe not since running WMC can be triggered using the GUIDE and Live-TV buttons! YES, pressing either of those will start WMC. Oh, I also assigned Alt-F4 to the "0" button so I can terminate any app in focus.
Given the overlap I described above, I have NOT seen any conflict on the MENU button. Or are you talking about the GREEN button?
