AVS › AVS Forum › Video Components › Home Theater Computers › High CPU usage with Flash H.264 and Radeon HD 5450
post #1 of 9
Hello,
My Radeon HD 5450 isn't accelerating flash videos. DXVA works fine in MPC-HC though. Have an ancient Athlon 64 3700+ so the CPU can't really handle decoding on it's own.
Using catalyst 12.8, and DXVAChecker indicates ModeH264_VLD_NoFGT_Flash is supported.
Any tips or advice is appreciated.
post #2 of 9
Uninstall flash. Restart. Donwlaod and install latest flash player. Enable hardware acceleration.
post #3 of 9
Ok, I uninstalled Flash for IE, Flash for FF, and chrome altogether (apparently Chrome has flash built in), restarted and reinstalled. Hardware acceleration was already enabled for all 3 flash players.
IE and FF are now using DXVA (used about 80% CPU, and the DXVAChecker trace log showed DXVA activity).
Chrome is still not using DXVA and is unwatchable with a 1080p youtube test video.
IE using Flash 11,4,402,265
FF using Flash 11,4,402,265
Chrome using Flash 11,3,31,232
Would like to get chrome working as it's my primary browser.
Any ideas?
post #4 of 9
post #5 of 9
That worked. Had to expand the flash choices and disable the chrome specific version.
I'm seeing 60-97% usage now with DXVA and flash. Is that normal?
Using MPC-HC i'm seeing ~7% for 1080p videos.
post #6 of 9
Can anyone confirm if that is normal or not?
post #7 of 9
There may not be a lot of people still using that ancient cpu. It's bottlenecking your GPU. Time for an upgrade.
post #8 of 9
Flash still relies more on CPU the GPU. So even with the 5450 it won't help you much. If your motherboard supports a Dual Core CPU, you should upgrade.
post #9 of 9
Ok, I found a socket 939 X2 4200+ for ~$26 on ebay. Gonna try that out as it's fairly cheap.
If i need to upgrade the CPU, I'll need a new motherboard, CPU and RAM. Would my power supply still work? It's a Seasonic S12-380 (http://www.newegg.com/Product/Product.aspx?Item=N82E16817151022). Sorry for the newb questions, haven't kept up with hardware since 2005 when I built this machine.
